Results 1 to 20 of 29
Thread: did i screw up
06-20-2007, 07:15 PM #1
did i screw up
by ordering the loudmouth 2 exhaust. im scared its going to be really quiet and not loud at all even though i have lt and ory
06-20-2007, 07:20 PM #2
- Nov 2006
- Broken Arrow, OK
06-21-2007, 01:14 AM #3
- May 2007
- Seattle
Jetstream Blue Metallic- 2008 Z06 Corvette
If the LM2 isn't loud enough, just order the resonator for $70.00 and get ready to piss off the neighbors! I ordered my Loud Mouth system from the headers back with BOTH the resonator and the muffler because I thought the same way you do. I can't tell you about the muffler, because I haven't put it on yet. The car sounds too good with the resonator. I have the cats though, which help a bit on the raspiness.
06-23-2007, 06:44 PM #4
it will be louddddddddd
06-23-2007, 06:54 PM #5
06-27-2007, 11:26 AM #6
2 more days and i get the exhaust, i cant wait...
06-27-2007, 11:27 AM #7
it should be an easy install right, should take like 15 minutes maybe?
06-27-2007, 02:22 PM #8
- Feb 2007
- Ft.pierce,fl
BADASSZ28
not exactly 15 minutes but it is easy , that thing is going to be so loud i have that setup and it acually annoying sometimes!!!!!!!!!!!
06-27-2007, 02:24 PM #9
bout 30min-1hr of time total. takes longer to remove/cut the stock I-pipe than it does to install the system...
no need to worry, your car will be loud...
links in my sig are with LT's/ORY and the LM1 for sound reference...2018 CTS-V: °°668rwhp/658rwtq°°
2013 ZL1: °°590rwhp/576rwtq°°
06-28-2007, 11:52 AM #10
whoa... why would i have to cut the i-pipe?
06-28-2007, 12:06 PM #11
06-28-2007, 01:59 PM #12
06-28-2007, 03:17 PM #13
okay this is what i bought
http://www.neweraperformanceparts.com/default.asp?S=503&A=E&PKV=3103931039a|0
the i pipe that is on the car, im no longer going to be using that? so if i cut it it wont matter?
I take it that the cat back that i bought goes all the way up to the y-pipe?
06-28-2007, 03:22 PM #14
also, am i going to have to do any welding? Because from what i was told, everything is bolt on.
06-28-2007, 04:20 PM #15
06-28-2007, 07:29 PM #16
Its all bolt on with clamps. They are talking about cutting the old exhaust in half to get it out from under the car. Other wise you have to take the shock etc. off so it will come off in 1 piece. I got mine welded on instead of the clamps. If you dont like the lm2 I have a lm resonator I can sell you cause I am replacing mine with Borls xr-1. Let me know.
06-28-2007, 07:36 PM #17
thank you
ill let you know tommarow when i get it on how i like it.
06-28-2007, 07:40 PM #18
No problem- just unbolt the fitting in front of the passenger side rear wheel then use a sawzall or hack saw the pipe behind the same wheel. Its pretty easy and u will see what I mean. If you have any problems let us know.
06-28-2007, 07:51 PM #19
thank you, you huys are a big help
06-29-2007, 07:33 AM #20
ahhhhh./........... where is fedex. im so bored i just want to put on my exhaust already!!!!!!!
Screw the 5.0
By silverWS6 in forum Almost Anything GoesReplies: 47Last Post: 04-09-2012, 04:01 PM -
How bad did I screw up?
By Spikito in forum Gun's & AmmoReplies: 6Last Post: 01-04-2010, 10:15 AM -
Screw best buy
By rajiv1998 in forum Computers / GamingReplies: 14Last Post: 12-07-2009, 02:46 PM -
Question: Why is there a screw there?
By clg82 in forum External EngineReplies: 6Last Post: 04-10-2009, 05:59 PM -
How to screw up a third gen...
By 86 IROC-Z in forum Almost Anything GoesReplies: 9Last Post: 04-27-2006, 03:05 PM
