Thread: Fuel Gauge Issues!
02-11-2007, 01:24 PM #1
- Feb 2007
- Earth
Fuel Gauge Issues!
I am having some fuel gauge issues with my 2002 Z06. I have roughly a half a tank in the car and my gauge is reading empty, my check gauges light is on and my panel display is reading 0 miles range left etc.
Is the fuel sender probably bad or is there something else I can check?
Thanks in advance!
02-11-2007, 02:20 PM #2
- Jul 2005
- Pembroke Pines,Florida
They are notorious for having bad senders.Sulfer does something to the sender.In my 2001 Z06 I replaced them about 6-7 times
2006 Victory Red Z06
490.42 rwhp 465.77 rwtq
02-11-2007, 03:48 PM #3
- Feb 2007
- Earth
02-11-2007, 03:52 PM #4
- Jul 2005
One in each tank
02-11-2007, 09:38 PM #5
- Feb 2007
- Earth
02-12-2007, 07:41 AM #6
- Oct 2006
- N.Andover
Black- 1986 Corvette
There are a couple service bulletins on this issue:
http://www.corvetteactioncenter.com/....php?qstId=243
http://www.corvetteactioncenter.com/....php?qstId=246
http://www.corvetteactioncenter.com/....php?qstId=483
http://www.corvetteactioncenter.com/....php?qstId=254
02-13-2007, 05:20 AM #7
Before you remove the fuel senders,try adding some Techron fuel system cleaner just before your next fuel fill up.One bottle treats 12 gallons of gas.Use enough to treat 18 gallons,which is the C5 fuel capacity.
Many C5 owners,including myself,have had good results using Techron to clean the deposits that form on the fuel senders.I add it to the gas each year before winter storage,and have had no problems with the fuel gauge yet. Good Luck!Last edited by Quicksilver Vert; 02-13-2007 at 05:30 AM.
02-15-2007, 05:15 PM #8
- Nov 2006
- Charleston, SC, but originally from Gainesville, FL
SILVER- 2002 Z28
Before you go spending a bunch of money on the sending unit swap, try this. Buy a couple of bottles of SEA FOAM (most auto parts stores carry it - $6.99/bottle - white with red writing on it, very plain). Go to a gas station that has top teir gasoline - CHEVRON, SHELL, 76, PHILLIPS 66 are a few. Pour the entire bottle into the tank and then pump it up. Do this one or two more tanks and it should clean the sending unit up a bit. This worked for me when my car did this about 11 months ago and I have never had a problem since. I also run a bottle about once a month.
Here is a link to top teir:
http://www.toptiergas.com/retailers.html
Here is a email I got from SEA FOAM:
Believe what you read in our literature and on the www.saefoamsales.com web site, it is truthful knowledge backed up by 66 years of customer satisfaction. Sea Foam, Trans Tune & Deep Creep are 100% petroleum oil blended product! NO CHEMICALS, so there is no danger of damage.
The number one use of Sea Foam Motor Treatment is in a fuel, be it gasoline (any brand or grade), gas/oil mix for 2 cycle applications, or diesel fuel.
Sea Foam used 1 - 16 ounce can to a minimum of about 8 gallons fuel, or a maximum of 25 gallons of fuel, is by design an added upper cylinder lubricant, moisture drier, carbon cleaner, fuel system residue cleaner, and fuel stabilizer (for up to 2 years at one ounce per gallon in most applications).
Other every day uses of Sea Foam Motor Treatment include:
1. In the crankcase oil ( including SYNTHETIC) as a pre cleaner to doing LOF service, an after LOF service additive, and a problem solver (or diagnostic tool) for other oil residue related crankcase system problems including sticky rings, lifters, etc.
Use at 1 1/2 ounces Sea Foam to each quart of crankcase oil, and give it a minimum of 30 minutes normal driving time before an LOF service or as a problem solver/diagnostic tool. Sea Foam works at making old oil residue back into liquid, so it may flow and be filtered. As an after service additive, Sea Foam works to liquefy that really tuff oil residue, and helps your oil keep from forming residue.
Like any other hi detergent oil product, Sea Foam may make your fresh oil get dirty, faster than normal, so monitor your oil for color and clarity at either mileage or time intervals, and change your oil when it gets dirty!
2. As an upper cylinder carbon cleaner, putting Sea Foam Motor Treatment in your fuel system will clean carbon off valves, cylinder heads, and pistons, AS YOU DRIVE! How long it takes will depend on how much carbon is present, how much product you use in your fuel, and your driving habits.
SO:
Sea Foam is used as an upper cylinder carbon cleaner by professional technicians who need "instant results" and also need to solve drivability problems that are carbon related. Simple to use on most vehicles, Sea Foam Motor Treatment can be used in conjunction with commercially available professional equipment designed for this service work, and can also be used by the "technically knowledgeable" DIY'er without special equipment. A thorough knowledge of the vehicle/engine induction system is required for using on EFI, TBI, and other "non traditional" induction systems.
Sea Foam Motor treatment is also used by professional technicians in equipment designed to clean fuel injectors at a 50/50 ratio gasoline to Sea Foam.
As for the other uses of Sea Foam Products:
Sea Foam offers its Motor Treatment in a spray can called DEEP CREEP, for ease of use in safely cleaning throttle bodies and EFI air inlets using a NON CHEMICAL, and in places where a spray might work easier/better than the Sea Foam Motor Treatment liquid. (small engines, side or updraft carbs, lubricating, cleaning, penetrating)
Sea Foam also offers TRANS TUNE for use in any hydraulic OIL, as a residue cleaner and moisture drier. Such systems include power steering, automatic transmissions, pump/plow assemblies, log splitter, etc. Again, 100% petroleum oil blended, TRANS TUNE is not a stop leak, but a cleaner and moisture drier.
Sea Foam also offers BUGS B GONE, a water based soap product for cleaning anything organic off any surface.
Bugs, molds, mildew, dirt, light oils, brake dust, road grime, etc. SAFE, it won't take the wax off your car! Use as directed, be creative, as a carpet/upholstery cleaner it can't be beat!
Hope this all helps!
Customer Service
Try it and I hope it helps,
Micah
03-08-2007, 06:46 AM #9
- Apr 2006
- Arizona
Torch red- 2000 Corvette Convertible
Fuel pump fuel guage issues on my '02 B4C
By ANDYZ28 in forum Camaro / SSReplies: 7Last Post: 12-29-2014, 10:30 AM -
Fuel Gauge Issues
By 02 CamaroSS in forum General HelpReplies: 4Last Post: 03-27-2011, 05:19 AM -
BOOST gauge, FUEL PRESSURE gauge, dual pillar pod
By onefastbird! in forum Parts Wanted / TradeReplies: 1Last Post: 04-26-2007, 08:31 PM -
Instrument gauge issues...Help!!
By Dawgbone003 in forum Stereo and ElectronicsReplies: 2Last Post: 09-04-2006, 04:21 PM -
Air/Fuel Gauge Issues
By jimbo98z in forum General HelpReplies: 10Last Post: 03-10-2006, 12:04 PM
