Results 1 to 13 of 13
    Nov 2011
    Guatemala
    Question bad clunking noise after lcas installation
    recently I installed a set of used umi adjustable lower control arms , the ones with the rod end ... now after 10 days or so after this my rear suspension is sounding weird something like when you have a worn shock , is this normal with adj lcas? what else should I check? do I have to extreme tight it? or torque it? please help
    Nov 2009
    Jacksonville FL
    TRIPLE BLACK
    2000 CAMARO SS M6 #2100
    I found the same thing with my aftermarket suspension parts. For about a month of driving after installing them I had to tighten them up, gorilla tight I might add, from time to time while they settled into place. After that I havent heard a peep in years.
    James Bond Spikito's Avatar
    2001 3.8 Black - sold
    2000 SS Black M6
    mine did it bad at first, but after some adjustments its not bad.
    did you check them for length before install? mine were short, which made my axle bang on the exhaust...moved the axle back 3/8 of an inch helped
    Senior Member 98maro's Avatar
    Feb 2010
    north bay california
    00 camaro ss M6 #6695
    i was worried about that on mine..never had that issue,,,not till now lol.
    i adjusted the lca the most i could..its very tight.. i even put it on a shorter length comparing to stock lca...
    then i adjusted it,, everithing seems fine,,, i hope that dont mess it up lol
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    Wink
    After x amount of miles (after installation), the lca's need to be re torqued, the specification calls out for 60lbs. torque to nuts.
    SteveC
    Coral Springs, Fl
    Sunset Orange Metalic
    Spherical rod end usually tend to make noise. Like mentioned, retorque and see if that helps
    Nov 2011
    Guatemala
    i install them same length of the stock lcas but I will re torque them and see what happens , Ill keep you guys updated
    Waiting on the Tree transamtom's Avatar
    Niagara Falls Ont.Canada
    1999 TA A4
    Did you put the rod end on the axle side or car side?
    2010 Camaro SIM 2SS/RS A6
    1999 TA A4 NBM
    12.265 at 110.52mph
    Nov 2011
    Guatemala
    Quote Originally Posted by transamtom View Post
    yes sir I did
    2000 SS Black M6
    that wasnt a yes or no question....
    Coral Springs, Fl
    My guess is there are rod ends on both sides
    Quote Originally Posted by torker View Post
    yes sir I did
    He's asking you if it looks like this
    Nov 2011
    Guatemala
    it looks exactly like that pic..
    last night I re tight bolts with no luck at all, it keeps sounding like something loose right there... I will put back the stock lca in one side just to make sure nothing else is sounding bad.
    also... if the bushing is low on grease can it make the sound worst?
  1. Clunking /rattle noise
    By xenergyx in forum General Help
    Last Post: 11-05-2014, 05:32 PM
  2. Clunking/Rattling Noise in my T/A
    By Caelynne1724 in forum General Help
    Last Post: 04-14-2011, 05:59 PM
  3. Help: clunking noise from underneath the car
    By bperk in forum Automatic Transmission
    Last Post: 05-10-2008, 10:07 AM
  4. Help: Clunking/rattling noise from driverside?
    By bgable in forum General Help
    Last Post: 04-20-2008, 06:55 AM
  5. Drivetrain clunking noise
    By mpowell04 in forum Manual Transmission
    Last Post: 04-24-2007, 01:38 PM
