Thread: Vacuum Gauge Connection
09-05-2008, 02:19 PM #1
- Sep 2008
- tn
Wanted to try here also, can you fellas with a vacuum gauge tell me where you hooked into the ls1 at. Some are using the brake power booster, but that just seems wrong. Thanks.
09-06-2008, 04:57 AM #2
That would work. Get a T fitting with a reducer for the gauge.
09-06-2008, 12:00 PM #3
you can use the AC controls vacuum line off the back of the intake. little fun getting to it, but it's small enough.
09-08-2008, 08:44 AM #4
- Jun 2008
- Annapolis, MD
BLK/BLK w/CGM Stripes- 2010 Camaro 2SS/M6
Is this for permanent mounting or just diagnostics? If it's permanent, any of the above methods. For diagnostics, I've used the port on the driver side behind the TB where the EVAP solenoid hooks to.
Help: Trans Am engine Vacuum line for Vacuum/Boost Gauge
By 1batt4u in forum General HelpReplies: 5Last Post: 11-13-2014, 05:42 PM -
erg blockoff vacuum gauge
By V8MUSCLE in forum External EngineReplies: 0Last Post: 03-03-2010, 04:12 AM -
Boost Gauge vs Boost/Vacuum Gauge
By ls1camino in forum Forced InductionReplies: 6Last Post: 09-28-2008, 06:02 PM -
By mudlizard in forum External EngineReplies: 1Last Post: 09-06-2008, 05:08 AM -
Vacuum gauge
By CKramer in forum General HelpReplies: 0Last Post: 05-08-2006, 02:43 PM
