Results 1 to 20 of 36
    Member One_Bad_TA's Avatar
    Jan 2008
    Cleveland, Ohio
    2000 Trans Am WS.6
    Transmission mount
    I have a 2000 TA M6 and when i step on the accelerator my shifter raises up in the console, you can also feel a little vibration in the car. I believe i have it narrowed down to the transmission mount. I was just wondering where i should get one and what kind? My car is stock as well with 106k on the clock
    Senior Member Zboner's Avatar
    cincinnati/northern ky
    99 SS
    stock? I would just get a stock replacement then
    Jan 2008
    Cleveland, Ohio
    2000 Trans Am WS.6
    I went to summitracing.com actually and they have Prothane mounts and other sites have similar mounts but from what i read the prothanes are stronger. I just dont want to get something that will fail again. I need one that can take abuse even if it is just stock power.
    99 SS
    if you get the Prothane its going to give you a lot of vibration, the rubber absorbes more of it, hell the stock mount lasted what over 100k miles?
    Jan 2008
    Cleveland, Ohio
    2000 Trans Am WS.6
    Not sure if its the stock one Ive only had the car for a couple months. And i read that stock seems to wear out cause they cant take abuse. But i also dont want vibration, seems like i should find a rubber one for what i have? I am not planning to get a lot of performance mods either
    Jan 2008
    Cleveland, Ohio
    2000 Trans Am WS.6
    ws6store has an Enegry Transmission mount that I believe others on this site have used but not sure about the vibration issue with one of those...
    99 SS
    I would just get the prothane one then, might as well.
    Jan 2008
    Cleveland, Ohio
    2000 Trans Am WS.6
    Ah that was my original plan, i dont know if you can answer this but how bad is the vibration from the prothane mount for city driving?
    99 SS
    I cant even remember what a stock F body feels like to drive man its been so long, when TSS switched his over he switched back to stock if I can remember right, but its like everything else you will get used to it im sure.
    Jan 2008
    Cleveland, Ohio
    2000 Trans Am WS.6
    Ah we will see. From summit the mount is bout 34 bucks shipped, autozone does not have them. If i wanted a stock one would my only choice be the dealership and any idea on a price?? And thanks for your help
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Quote Originally Posted by One_Bad_TA View Post
    Not bad at all. I honestly noticed very little difference, I have the Energy Suspension poly mount.
    It really stiffens it up nicely, nothing like having the shifter jumping side to side or up and down when you're trying to shift!! With the poly mount it is stiff as hell, the trans moves very little regardless of how hard you're running it.
    I also installed poly motor mounts when I did my headers, definitely worth it. The vibrations are not very noticeable, doesn't bother me at all in daily driving, highway or city.
    Jan 2008
    Cleveland, Ohio
    2000 Trans Am WS.6
    So where did u get the Energy mount from? I think i might go that way.
    Member crazy dave ls1's Avatar
    Aug 2008
    texas
    2002 z/28
    i had a 91 z after a 2500 stall and 3.73:1 gears i went through about 5 in 3 months so i made a solid steel mount the vibrations were equivalent to riding a hardtail harley but it never broke again.now the one is broken on my 02 but i wont be going that route yet mine only lasted 60k
    Jan 2008
    Cleveland, Ohio
    2000 Trans Am WS.6
    Im looking for something that will last but not make the car unbearable to drive because of vibration. Arg tough decision, i doubt I could find a stock rubber one for cheaper than the poly ones. Which also wont last as long. Plus im stock i dont need to fabricate anything crazy
    Aug 2008
    texas
    2002 z/28
    there must be a way to have the best of both worlds.like you im undecided what to do but im really tired of the tranny bouncing off the bottom of the car
    Jan 2008
    Cleveland, Ohio
    2000 Trans Am WS.6
    So am I, but i want to fix this quickly so i dont break anything else. And to end the slight vibration from the broken one
    Member stephen02ws6's Avatar
    Dalzell, Illinois
    red with black stripes
    2002 Trans Am WS6
    there was a vibration when i had the prothane motor and trans mount in. it was kinda bad at first but it got better after a couple days. i also got used to it so i dont notice it as much.
    NJ
    SGM
    1998 Trans Am WS6
    Ws6 Store, $24. Its money well spent, you won't regret going poly.
    Aug 2008
    texas
    2002 z/28
    Quote Originally Posted by Wesman View Post
    do you have a web address for ws6 store
    in my Trans Am
    2000 Trans Am WS6
    dont buy prothane they are pieces of shit. GET AN ENERGY SUSPENSION MOUNT.......dont use the preload plate, and grind down the 2 humps on the top ( you willl understand when you get it) grind the humps down so they are level with the rest of the mount, then install. you will never have to worry about it again. If you decide you want a stock one let me know. I have a brand new one i got , never used, b/c i went with the ES one instead.
  1. transmission mount
    By V8MUSCLE in forum General Help
    Last Post: 02-28-2010, 05:14 PM
  2. Transmission mount
    By steven strickland in forum Manual Transmission
    Last Post: 09-04-2008, 11:26 AM
  3. Transmission Mount
    By steven strickland in forum Drivetrain
    Last Post: 08-24-2008, 02:24 PM
  4. Transmission mount?????
    By Anwazi in forum Automatic Transmission
    Last Post: 05-07-2008, 05:08 AM
  5. How do you tell if a transmission mount is bad?
    By Rhinohuey in forum Drivetrain
    Last Post: 07-22-2007, 10:31 AM
