Thread: Bump Stops
    Junior Member Fastdaddy's Avatar
    clinton, ms
    1999 Trans Am WS6
    Bump Stops
    1999 Pontiac Trans Am WS6
    I just bought this car and I am trying to figure what all this guy did to it..I am working on rear suspension issues now. Where are, or would have been located, are the bump stops for this car. Also, I need input on Stano 1.2 springs. This car has Eibach pro's, which I do not like, with KYB AGX shocks. Car is slamming in rear on every bump. Give me some input. Thanks
    This would get a better responce in the suspension section, but...
    Bump stops are [or should be] directly above the rear axle. You should be able to look up and visualize where the axle could/would hit the car's frame-there should be a bumper there. I don't know why anyone would take it out? Maybe there are ones for lowered application-which if you find one, let me know, b/c i would love it.
    KYB's are junk and stranos' springs won't help. he'll sell you a set of shocks from KONI that will for sure. I have Koni's and Pro kit and love the way it handles on a near-softest setting.
    clinton, ms
    1999 Trans Am WS6
    Bump Stops
    I have rethreaded this posting in the suspension section.
    clinton, ms
    1999 Trans Am WS6
    I am beginning to think the same about KYB. Do you have recomendation for which Koni shock to go with the Eibach springs. Do they need to be adjustable. Also I have found that the tires he has put on are 275/40-18, which are an inch taller than stock, could be an issue also. Thanks for the response. I have reposted thread in suspension section also.
    Impounded MikeSomething's Avatar
    Old Bridge, NJ
    Pewter Metallic
    '00 Z/28
    Stupid question but did you adjust the firmness of the shocks and struts? That might help ya out alittle.
    clinton, ms
    1999 Trans Am WS6
    Tried it all. Have set from 3 to 8. Strano's said to set them on the rear around 3 to 5. I was also told that Eibach springs can be inconsistent in their processing, that some springs produced could cause car to be lower than stated claim. I believe these springs are lowering my rear as much as 1.75, with taller tires that is too low. Any knowledge of H&R springs? Also the wheel hop is killing me. Comments??
  1. Bump stops wanted
    By LETHALxLS1 in forum Parts Wanted / Trade
    Last Post: 11-14-2012, 08:16 AM
  2. Bump stops
    By MeanMachine1 in forum Suspension and Handling
    Last Post: 09-16-2012, 05:46 AM
  3. Bump Stops
    By bad4ss in forum Suspension and Handling
    Last Post: 03-14-2011, 10:11 AM
  4. Question: bump stops
    By JoshuaGrooms83 in forum Suspension and Handling
    Last Post: 11-24-2010, 08:01 PM
  5. Bump stops
    By jd2002ss in forum Suspension and Handling
    Last Post: 10-30-2009, 01:02 PM
