Results 1 to 20 of 20
Thread: A4 question
04-23-2008, 12:11 PM #1
A4 question
might be kind of a dumb question cause im kinda new to this ls1 tech stuff, but im wonder about my gears there is D,3,2,1 is "D" over drive and is "3" regular drive i have had people tell mixed things anyone know on here forsure??? thanks alot - Jason
04-23-2008, 01:12 PM #2
- Apr 2007
- Newport, RI
Navy Blue Metallic- '00 Formy A4
Yeah, "3" is drive. If you put it in "3", the transmission will shift up until 3rd gear, but it will not shift into overdrive.
If you put it in "D", it will shift right up until 4th (overdrive).
Unless you're in an area with slow speeds (30-40mph) and it keeps shifting back and forth, just leave it in D.
That's what I do with mine.
04-23-2008, 09:02 PM #3
I thought it was a 4 speed with over drive (making it a 5 speed with only 4 gears you can shift through yourself). Meaning that "D" is drive and when you reach a certain rpm it goes into overdrive. I'm pertty sure thats how mine works cuz when I shift 1,2,3,4 myself I still go into one more gear after I'm in 4th and I let the rpm's down a bit.
04-24-2008, 02:30 AM #4
- Apr 2007
- Newport, RI
Nope, it's a 3 speed with overdrive, hence the "4" in 4L60E.
The extra shift you feel is probably the converter locking up.
04-24-2008, 02:52 AM #5
- Nov 2006
- Indianapolis
Yup, the extra "shift" you feel is the torque convertor locking up, like a clutch is locked up in a manual trans car, gives better gas mileage. Also, just leave it in "D" unless like StuntMan says, you have a long commute at 30-40 MPH.
04-24-2008, 04:00 PM #6
Yep. Watch the tach.
BTW if you put a stock 4L60E in 2 from a dead stop, you will start in second.
There is a bunch of technology in that trans. I rec. leaving it in OD and let the computer do the "thinking." I even leave it in OD at the track. It can shift a he!! of a lot faster than me.Drag racing...just another numbers game.
Vortech Super Charger, 9" w/4.11, 3200 Stall, BMR SFC, BMR TracPak, !MAF screen, 160 T-Stat.
04-24-2008, 04:15 PM #7
04-24-2008, 04:16 PM #8
04-24-2008, 04:23 PM #9
04-24-2008, 04:33 PM #10
04-24-2008, 04:38 PM #11
04-24-2008, 10:12 PM #12
Oh ok thanks for clearing that up I guess the whole 4l60e does make sence, I didn't even think about that when I put that last post up. As fas as leaving it in "D" I like to go through 1st,2nd,3rd,4th myself when I'm "running it"
04-25-2008, 04:21 AM #13
04-25-2008, 04:26 AM #14
04-25-2008, 08:21 AM #15
Ya, I'm aware of the delayed shifting from the computer if thats what your talking about. I've got it down pretty good thus far but I understand what everyone is saying about it's better to leave it in drive, It's just so fun some times to run through the gears yourself. (I don't do it all the time though)
04-25-2008, 09:03 AM #16
- Oct 2007
- Muncie, IN
00 TA PWTR, 98 VertTA NBM- 80 TA BLK, 80 Formula NBM
me too. . . i thought i saw somewhere that sold some sort of adapter to add on to our stock shifter to make it like a "slap stick", like aftermarkets . . . anyone else heard of this? if you dont know what im talkin about it allows you to shift manually by bumpin the shifter forward but prevents you from bumpin it too far (like one gear to far or into neutral).
04-25-2008, 05:14 PM #17
04-25-2008, 06:14 PM #18
- Jun 2007
- Parma Heights, Ohio
SOM- 99 Trans Am
I f***in hate my auto. Once this trans goes ill be putting in a 6spd. The only time i really take it out of D is when im racing from a roll. Ill throw it into 1st or 2nd so i can get my rpms up and have the converter already locked so i can get the jump.
04-25-2008, 08:57 PM #19
Only problem with that is (and this doesn't apply to everyone) some times you CAN miss a gear. don't get me wrong though I love the 6-speed I would have bought one but I got a kick ass deal on mine and the 6-speeds where I lived were like 3-4k more than mine so I make due for now.
04-26-2008, 05:32 AM #20
- Nov 2006
- Indianapolis
^^Well that is true, it is a lot easier to not miss a gear shift with an auto trans.
Since I never had my shift points tuned in my '98 AT car, I gained .2-.3 at the drag strip by learning when to shift it manually just before the rev limiter. It would shift at about 5700 RPM if I left it to do its' own thing.
speedometer question + top speed question
By Krazy351w in forum General HelpReplies: 7Last Post: 06-21-2007, 05:51 PM -
HPIII question (not the same old question)
By slims00ls1z28 in forum Computer & TuningReplies: 5Last Post: 06-01-2007, 04:55 PM -
97 Bird Headlight question also engine noise question
By Zapper2003 in forum General HelpReplies: 2Last Post: 12-13-2006, 03:03 AM -
Speedometer question, RPO question
By acrylicophobia in forum Firebird / WS6Replies: 12Last Post: 11-02-2006, 07:08 AM -
Sex Question spinoff- PORN QUESTION
By egaian in forum Almost Anything GoesReplies: 77Last Post: 07-26-2006, 03:07 PM
