02-18-2008, 07:07 AM #1
can I use a 99 fuel tank in my 98 formula
Hi fellow members
Where I work we got in a 99 formula that was wreck that we strip.What I want to know is will the plastic tank & fuel pump work in my 98 formula.My pump is kicking the bucket so I Want to upgrade to the bigger plastic tank instead of my steel tank.
Thank you
crazyforgms
02-18-2008, 07:51 AM #2
I'd have to dig around because for some reason I have it in my head that you can't use the pump but I might be wrong on that. Seems like for some reason 98's can't use the 99+ pump but I'm not sure about that. I do know that if you swap tanks you will want to swap pumps because the 99+ tanks don't have baffles in them and use a bucket on the pump where as the 98's don't use the bucket on the pump because they have baffles in them. Let me dig around and think about it for a bit if someone else doesn't chime in, I could be totally wrong on the pump. Maybe I'm thinking that if you swap tanks you have to swap pumps also.
02-19-2008, 05:44 AM #3
thank for the info orion.I think there is something diffrent between the two pumps. the 99+ have a sensor the 98 do not have.That why I am asking .I dont care if I have to get a new pump but will the 98 pump assumbley work with the 99 tank.
Happy Motoring
1969 chevelle Lemans Blue 350 v8
1994 Roadmonster garnet red LT1
1998 formula Ls1
02-19-2008, 05:46 AM #4
ps sorry for the spelling did not have my coffee this morning
lol
02-19-2008, 06:14 AM #5
no, the 98 pump will not work in a 99+ tank. For one thing they mount differently, the 98's bolt on and the 99's twist on. There's also the bucket and venturi feed system on the 99+ that the 98 doesn't have. I did some digging around and never really found any concrete info if swapping the tank and pump from a 99 back to a 98 would work. I think possibly the return lines are different on them.
Help: 98 TA fuel smell coming out of the fuel tank neck/cap
By JayTA98 in forum General HelpReplies: 23Last Post: 04-09-2014, 09:35 AM -
can't drop my 98 fuel tank!!
By JayTA98 in forum General HelpReplies: 10Last Post: 04-17-2010, 04:40 PM -
fuel tank
By pocket rocket in forum GTOReplies: 7Last Post: 11-09-2009, 04:33 AM -
F/S: 255 LPH in tank fuel pump
By nevrlift in forum Western MembersReplies: 0Last Post: 09-11-2007, 02:22 PM -
Sugar in Fuel Tank!
By RedDemon2 in forum General HelpReplies: 24Last Post: 05-20-2007, 04:47 PM
