08-14-2007, 05:32 PM #1
- Jun 2007
- Baltimore, MD.
Bright Red- 2000 Pontiac Trans Am WS6
New valve springs w/stock cam question
I plan on a cam swap over the Fall/Winter and know that as part of that I'll need new valvesprings.
The new cam is 226/226 w/.595" lift on intake and exhaust.
The springs will be PAC-1218's. https://securehost98.hrwebservices.n...&productId=183
Can I install springs ahead of time, or would they be too stiff for stock cam?
The car has 111,000 miles, so I'm sure new springs would be a help no matter if I swap cams or not, but don't want to hurt anything by having springs that are too heavy, or stiff, or whatever the term is...
Thanks.Last edited by rel3rd; 08-14-2007 at 05:39 PM.
2002 Silverado Z71 ECSB HPTuners tuned by yours truly
2000 Pontiac Trans Am WS6 6.0, 4L80E, 9" rear
webpage: http://www.fquick.com/rel3rd/
08-14-2007, 05:38 PM #2
- Thornton, CO
I don't see why not.
But it would be easier to just do it all at once.
08-14-2007, 06:47 PM #3
it'll be fine for a stock cam.
08-15-2007, 12:56 PM #4
- Oct 2005
- RI
Mag Red- 2002 Vette
The only concern I would have is the stock pushrods, but I also know of some aftermarket vendors who don't swap pushrods when a cam change is done so you will likely be OK.
Are the stock Ls1 valve springs weak?
By importssuck in forum Internal EngineReplies: 5Last Post: 05-03-2012, 05:14 PM -
Stock LS1 Valve Springs...
By OnEbAdReDSS in forum Internal EngineReplies: 13Last Post: 08-08-2008, 01:17 PM -
STock Valve Springs
By redss454 in forum Internal EngineReplies: 6Last Post: 03-27-2007, 03:45 PM -
IL: stock 2002 LS1 cam and valve springs
By shaitiger in forum Parts For Sale / TradeReplies: 3Last Post: 08-15-2006, 07:39 AM -
Stock valve springs?
By rnl35thss in forum Internal EngineReplies: 4Last Post: 02-15-2006, 06:15 PM
