    Columbia, MO
    Medium Blue Metallic
    1999 Pontiac Trans Am
    Gauges and radio don't work?
    OK so I took out the head unit in my 1999 trans am to reinstall the stocker while I wait for my new alpine to arrive. I forgot to disconnect the battery before I unplugged everything. Put the stock stuff back in, and none of the lights on my gauge cluster light up (SES, seatbelts, etc). Also the mph, tach, and fuel gauges don't work. Of course mileage doesn't show up either. And the stock radio doesn't work either. I checked/replaced all the fuses by the door but no dice. Weird enough the blinker lights on the cluster still work fine. How should I begin diagnosing this? And could the radio and gauge problems be related?
    Asshole bige97's Avatar
    Virginia
    '01 Silverado
    do you have fuses under the hood or are they all under the dash
    Bragg NC
    Met. Sunset Orange
    01 SS
    Check your fuses, should also be a box under the hood. If no luck then disconnect the battery and unhook the factory radio and see what happens. Sounds like ya blew a fuse thou
    J
    the chief oldguy's Avatar
    SC
    1998 TA Convertible
    Cool
    Had a similar problem with a 97 Camaro. It turned out to be the ignition switch.
    d
    2002 z28
    try replace the only RED fuse on left thats for the whole cluster but not for the radio. you might of grounded out on something
    STL
    RED
    2001 CAMARO Z
    fuse
    d
    2002 z28
    fuse
  1. Gauges dont work
    By 02CamaroZ28WithLS1 in forum Stereo and Electronics
    Last Post: 05-18-2011, 07:59 PM
  2. Question: Gauges don't work in v6 to v8 swap...
    By allbaugh_04 in forum General Help
    Last Post: 03-18-2011, 06:02 PM
  3. AutoMeter Gauges (Making them work!)
    By camaroluvr447 in forum External Engine
    Last Post: 05-09-2010, 11:24 PM
  4. Radio doesnt work but CD player does....
    By cujo in forum Stereo and Electronics
    Last Post: 11-15-2009, 09:58 AM
  5. new radio no dash gauges now
    By twoolley08 in forum Stereo and Electronics
    Last Post: 07-20-2008, 06:42 AM
