    Junior Member 2001z's Avatar
    Feb 2006
    sc
    2001 z28
    Line lock/ brake line ?
    I bought a moroso linelock noid and have a simple question when run new lines myself can i use a male fitting with compresson on the other side instead of using a bubble flare on he abs block and the master ? The reason i ask is becouse no one seems to know what a bubble flare is and is almost impossible to buy a tool arond here and off the net they are crazy . If anyone knows where i can buy the prebent lines or lines with the flares already on them and i can bend them myself let me know or if i can use compression that would be great !!! Also what size would that be in a male compression fitting? isnt the front line from the master to the abs block 3/16?
    Thanks for any info you can give me
    __________________
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Quote Originally Posted by 2001z View Post
    __________________
    The bubble flare your referring to is called a ISO flare. And there is NO tool to buy cause it's not a flare you can do yourself without VERY expensive tooling.
    ALL "new" style brake systems that are ABS use a ISO flare on the brake lines. What you need to do is go the the scrap yard with a line wrench and a tubing cutter.
    I cut pieces off the cars that have lines that are easy to get to. Then those ends you get with the flares you splice into with a regular double flare union.
    ALL fittings going into the stock ABS lines will need a ISO "Nipple" flare.
    Feb 2006
    sc
    2001 z28
    cool but if i could cant i jsut keep my two flares i have and just cut it in the middle and flare those ore compression them to the noid ? Thats what im trying to figure out is if i can just cut them and tap into each end with a union ?
    Feb 2006
    sc
    2001 z28
    that is a good idea though im gonna hit the scrap yard this week!!! Is it 3/16th and what size is the fittings?
  1. Question: line lock
    By jodmari in forum General Help
    Last Post: 05-07-2015, 06:21 AM
  2. Help: Line Lock
    By herculesrider1 in forum General Help
    Last Post: 11-05-2010, 01:02 PM
  3. SLP line lock *NIB*
    By Packy in forum Parts For Sale / Trade
    Last Post: 03-31-2009, 02:02 PM
  4. line lock
    By jbb6811 in forum Drag Racing
    Last Post: 10-22-2008, 10:54 AM
  5. Ebay garage sale!! Fuel Pump, Line lock, Brake lines 9"
    By Phantompooper in forum Parts For Sale / Trade
    Last Post: 05-04-2007, 06:28 AM
