Results 1 to 16 of 16
Thread: Small Step
02-20-2007, 08:08 PM #1
- Apr 2006
- Chowchilla CA
White- 2001 Z28
Small Step
I am about to make a small hp increase in my 2001 Z28. I have all the bolt ons, and free mods. Now I intend to put in a GM Hot Cam (.525 lift),LS6 valve springs, and Edelbrock shorty headers. Please note the I am running Crane Gold (1.8) Roller Rocker Arms. Right now my best dyno pull is 337 hp.
I am using the shorty headers as this is a DD and I must pass CA emissions. Any thoughts on this combination?
02-21-2007, 03:57 AM #2Originally Posted by lonewolf37
02-21-2007, 11:55 AM #3
- Apr 2006
- Chowchilla CA
White- 2001 Z28
I am hesitant to put that much cam in with stock heads and short headers. I am trying to keep it a relatively mild motor.
02-21-2007, 12:02 PM #4Originally Posted by lonewolf37
Don't go Hotcam, trust me...
02-21-2007, 12:14 PM #5
02-21-2007, 09:29 PM #6
- Apr 2006
- Chowchilla CA
White- 2001 Z28
Thanks for the advice, if I go with that cam what springs and retainers should I use?
02-21-2007, 09:32 PM #7
- Apr 2006
- Chowchilla CA
White- 2001 Z28
The old man cam seems like a good choice for an old man like me. Thamks for the advice.
02-21-2007, 09:46 PM #8
- Sep 2006
- Canby, Oregon
Pewter- 1999 Camaro SS-M6 #1775
Just some input on headers....
for the price of shorties compared to the performance gain you would be better off getting Long Tubes, they have a much better performance gain and sounds great.
JMO
02-22-2007, 03:10 AM #9
That's not what I was implying, I'm honestly not sure why Thunder Racing gave it that name, especially considering that it's a much better all around cam than the HotCam, as well as the ZO6 cam....
Again though, had you not of had headers, it would have been the Thunder Racing's CheaTR cam all the way. Ultimately though, I'd honestly consider a custom grind tailored to your specific needs....
Some other very good choices are MTI's Stealth grinds (I or II). Either of these cams above will easily pass emissions, and sound entirely stock, til you nail the throttle of course. It's all personal preference, and where you want that power to be prevalent in your RPM....
That's why a custom grind is best. Rather than purchase a specific cam, then spend the rest of your time trying to adapt parts to the camshaft, why not consider having Thunder Racing grind a specific camshaft for your application. That is the very best way to select a cam, and in the end, you'll be more pleased with the resuts....
Good luck.
02-22-2007, 10:17 AM #10
he can't cause he lives in CA. emissions, Emissions, EMISSIONS!!!
BTW, ditch the Hot cam and got a little bigger. for the money spent on a cam get one you would enjoy. a Comp224 or a TR224 A114lsa, is a good all around mild cam that makes good power, good on gas usage, excellent daily driver performer all around...
02-22-2007, 10:48 AM #11
- Sep 2006
- Canby, Oregon
oops i didnt even look at that....
are mid tubes emissions legal? or just not worth getting?
02-22-2007, 12:47 PM #12
- Apr 2006
- Chowchilla CA
White- 2001 Z28
I am resolved to a higher lift camshaft, but what about springs and retainers?
Yes, I must pass CA emissions.
02-22-2007, 01:06 PM #13Originally Posted by lonewolf37
02-23-2007, 06:04 AM #14
in CA you have to keep the cats in the original factory location. the only headers that you can get to meet those smog/emissions law is to get shorty headers. both mid-tubes and long tube headers either relocate or remove the cats from the factory location all together voiding the CA smog/emissions laws...
now in other states, emission laws are different. here in TX for example you can have LT headers on your car, as long as you have cats. another example is KS, they have no emission testing so once you pass inspection when you to title your car, you can remove the cats (though still federally illegal) and run header/ory setup and just pray you dont get pulled over and your car looked at...
02-23-2007, 02:11 PM #15
- Apr 2006
- Chowchilla CA
White- 2001 Z28
Any ideas about how much of a gain I can expect with this setup?
02-25-2007, 08:50 PM #16
- Oct 2006
- Florida
Navy Blue Metallic- 2002 Trans Am WS6
Thank God I live in Florida and have no emissions testing. The only thing I'm going to have to worry about is the noise ordinance.
Step By Step: Tight Locking Trans Dipstick
By Ed Blown Vert in forum General HelpReplies: 0Last Post: 10-10-2014, 02:10 AM -
Step By Step: 4L60E Overdrive Transmission Swap
By Ed Blown Vert in forum General HelpReplies: 0Last Post: 08-12-2014, 02:10 AM -
Step By Step - Chrysler 440 Six Pack Electric Choke
By Ed Blown Vert in forum General HelpReplies: 1Last Post: 06-24-2014, 05:11 AM -
Brake System Maintenance - Flushed Out - CHP Step By Step
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 01-29-2011, 02:30 AM -
Chevy 630 HP Small-Block Engine - Rockin'- Step By Step - CHP
By Ed Blown Vert in forum Camaro / SSReplies: 1Last Post: 10-19-2007, 04:04 AM
