09-25-2005, 03:09 PM #1
- Sep 2005
- Tennessee
Black- 2004 Infiniti g35
Wanting to switch over a m6 to a 350 turbo
Will this work with my 99 camaro and what changes will i have to make.
09-26-2005, 08:49 AM #2BlackHawk T/AGuest
Why not a 400?
09-28-2005, 03:21 PM #3
- Tomball, TX
Red-orange metallic- 1998 Firebird Formula
It will work. You'll need to add a metal plate over the hole in your floorboard to mount your shifter. Possibly modify your M6 crossmember or just buy an BMR unit with tq arm provision.(unless you have an aftermarket tq arm) If you get a 9" tailshaft tranny(th350), you can use your stock driveshaft.
When I did a A4 to th350 swap.. I had to
Delete codes pertaining to the 4L60E
install ratchet shifter
set up tranny to work with electronic speedo
buy a new driveshaft
mod my A4 crossmember
buy new th350 converter
buy a Lokar Dipstick
run a vaccum line from back of intake
install tranny cooler
with the m6 you wont have to worry about the tranny codes.
You'll have to splice into your clutch pedal switch to start the car and hook up your reverse wiring for the back up lights to come on.
10-02-2005, 06:02 PM #4RED98WS6Guest
Question for you guys. I am thinking of doing the same thing. I was going to swap someone my M6 for their built 4L60E. But starting hearing that even
4L60E, no matter how much their built up, tends to crap out eventually.
My question is: does anyone know what the limitations are of a 'built' TH350?
I'm leaning towards a TH400 since I feel like the TH350, even when built to the hilt, has some limitations as the 4L60E does...
wire from stop lamp switch to turn/hazard switch?
By swisscheese in forum Stereo and ElectronicsReplies: 1Last Post: 08-11-2008, 11:22 PM -
Wanting a new car.
By jperkins812 in forum New Member IntroductionsReplies: 1Last Post: 07-12-2007, 06:02 AM -
FS: Nitrous Outlet switch panel & WOT switch
By MagicMan in forum Parts For Sale / TradeReplies: 11Last Post: 11-28-2006, 08:12 AM -
Wanting to Add 2 12's and a amp, What should i do?
By John2005 in forum Stereo and ElectronicsReplies: 11Last Post: 12-27-2005, 07:17 PM
