Results 1 to 10 of 10
Thread: stock push rod length?
09-04-2005, 01:14 PM #1
- Pittsburgh, PA
who knows what the stock length of an Ls1 pushrod is?
09-04-2005, 01:19 PM #2
- Aug 1999
- Arizona
7.40
09-04-2005, 07:26 PM #3
- Thornton, CO
Measure one. They are said to be 7.400.
I think most measure out closer to 7.380.2008 Trailblazer SS
Lowered, HID's, tinted.
09-19-2005, 06:48 PM #4
Yep, barely less than 7.4
09-19-2005, 08:21 PM #5
- OC, California
Arctic White- 1999 Z28 M6
so then if you were just wanting to replace your stock rods cuz one was bent, would you get 7.4 or something a little less?
09-20-2005, 04:19 PM #6
- Thornton, CO
Get 7.400 if you are replacing stockers.
Although, I would recommend sticking to stock pushrods unless you have upgraded your valvetrain.
09-20-2005, 04:28 PM #7
If he bent one, shouldn't he get hardened pushrods this time?
While you got the motor apart, it might be a good idea to spend some money on some more go fast parts though2002 Trans Am 6sp, SLP lid, Holley filter, Shaner S3 TB, Jet Hot long tubes and cats, FRA, HP tuners, Hotchkis STB and LCAs. TEA stage 1.5 5.3 heads, Comp 220/224 114 +2, UMI Boxed SFCs, Edelbrock PHR. Moser 9" 4.11 gears.
**FOR SALE**: http://www.ls1.com/forums/showthread.php?t=60478
09-20-2005, 04:55 PM #8
- Thornton, CO
If he bent a pushrod this time, with hardened pushrods he will bend a valve stem next time.
Valvetrain stablitily is a must. The stock LS1 valvesprings barely hold the stock cam. Meaning more chance for valve float...in which case, the stock pushrods may save you when they bend.
09-20-2005, 06:41 PM #9
I did not know that.
Good to know. But, since I'm getting my heads/cam in the mail on thursday, the entire valvetrain is gonna be beefed up. So for me it won't matter.
05-08-2012, 08:07 AM #10
- Apr 2010
- IN
would 7.425 bee too big then?
How to Measuring for Correct Push Rod Length.
By SMWS6TA in forum Internal EngineReplies: 4Last Post: 01-14-2023, 11:24 PM -
Push Rod Length
By meathammer in forum Internal EngineReplies: 7Last Post: 03-25-2011, 03:56 PM -
How To Check For Proper Pushrod Length - Push It -
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 09-28-2009, 10:20 PM -
Push Rod Length for 383 Stroker...Help!!
By Lawdawg4623 in forum Internal EngineReplies: 7Last Post: 11-01-2006, 01:47 PM -
stock PHB length
By ninobrn99 in forum DrivetrainReplies: 4Last Post: 12-05-2005, 04:47 PM
