Thread: 1980 trans am rear end
07-14-2016, 04:30 PM #1
- May 2016
- flower mound
Black- 1980
I just had a ls dropped in my 80 TA Now the rear end seems messed up, I want to change it out to something with disc breaks maybe with 373 gears any ideas what donor would fit? Thank you all
07-15-2016, 07:14 AM #2
Do you know what's wrong? Slipping or broken teeth on the gear, howling?
These above are relatively simple in that depending on what the issue is what needs to be done to rebuild it.
Now if you're looking to beef it up and and a built rear end you have several options but some of your problems are going to be suspension setup, particularly working with the leaf springs.
Do you not bother with a stock 4th gen rear, they are weak and not worth building up.
Several companies out there that build rears in Ford 8.8, 9", and GM 12 bolt are the most common. Dana60 is if you're super serious about track.
Regarding the disk brake conversion, there are plenty of kits that you can convert to. IIRC you can even get the stock rear setup from a 4th gen and use on your car.
I have fab a 8.8 for mine. So far so good.
07-15-2016, 10:39 AM #3
07-15-2016, 11:32 AM #4
I haven't had the "pleasure" of working on one yet. That's why I asked what was wrong with it. If it's slipping that's easy to fix, broke ring gear, again easy.
07-15-2016, 02:51 PM #5
as was stated, the 80's 10 bolt rear had an 8.5" ring gear, perfectly fine for stock ls power. gearsets for it are easy to find, as are aftermarket differentials. Right Stuff Detailing sells a very affordable disc brake conversion that's simple to install, especially since the axles have to be pulled to correct whatever the issue may be.
07-15-2016, 02:56 PM #6
- May 2016
- flower mound
Black- 1980
It's making a popping sound and some grinding as well mostly when turning at low speed . It would seem to have low gears as it doesn't jump off the line but curses at 55 at really low rpm.
So I was hoping to just pop in a whole another rear end in but doesn't sound like there is a fit. I'm not a racer this is a driver and weekend fun.
07-15-2016, 03:53 PM #7
Sounds like bearings
00 FB Vert - Stock
07-15-2016, 04:45 PM #8
the is a bit more to it than just swapping the rear out in favor of disc brakes, too. you will also need a disc brake master cylinder and proportioning valve. to make matters worse, I have read on more than one account that the factory disc setup wasn't very good, and when compared stock for stock against drums, they're pretty much on the same playing field and neither one is better than the other.
1980 Pontiac Trans Am promo
By blk99ws6ta in forum Firebird / WS6Replies: 1Last Post: 09-01-2012, 11:40 AM -
1980 Trans Am (Again)
By SHines-IT in forum Almost Anything GoesReplies: 68Last Post: 02-03-2010, 04:27 PM -
1980 Trans Am
By SHines-IT in forum Almost Anything GoesReplies: 91Last Post: 10-13-2009, 09:28 PM -
1980 Pontiac Trans Am - Shootout
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 10-09-2009, 12:11 AM -
1980 trans am for trade
By jim mullen in forum Vehicles For Sale / TradeReplies: 1Last Post: 10-31-2006, 04:54 PM
