Results 1 to 13 of 13
Thread: Heads and Cam Packages?
04-07-2016, 12:55 PM #1
- Apr 2016
- North Carolina
Pewter- 2000 Camaro SS
I have a 2000 Camaro SS with 103,xxx miles looking to do a heads and cam package what would be a great setup. I was looking at the texas performance but I want a setup where I don't need to run race fuel. Then after that what kind of pistons and valves would be a start?
04-07-2016, 04:56 PM #2
Budget & end goals?
Still want it to have street manners or heavy track duty?
Other supporting mods like suspension, rear end, transmission?http://www.ls1.com/forums/f7/my-6-liter-build-174257/
00 FB Vert - Stock
04-08-2016, 03:03 AM #3
Welcome to the site! Trick Flow has a nice looking package that I have considered from time to time. If I recall, there are three separate setups to choose from.
04-08-2016, 04:32 AM #4
If I were to do heads, I'd likely go with the ones Jeff mentions or AFR. Check out Brian Tooling Racing (BTR) too.
04-08-2016, 09:31 AM #5
- Apr 2010
- Alabama
Trickflow hands down. I have them and can post pics if you want.
Sent from my HTC6535LVW using Tapatalk1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
04-08-2016, 11:00 AM #6
^^ all of these are why i asked my 3 questions up front.
04-08-2016, 12:55 PM #7
- Apr 2016
- south dakota
black- 1999 WS6
Help!!!
Do mean to hijack new to ls1 forum. I looking for advice in exhaust and idk how to start a new thread. Can someone explain how???!!
04-09-2016, 03:08 AM #8
Welcome! Go to the "Forum" page on the site by selecting that tab under our logo at the top of the page. Select the appropriate section of the site for your topic, in this case either "General Help" or "External Engine" would be appropriate. Once you open up the specific topic section, there is a button at the top left within the forum box that reads "+ Post New Thread". Click that and you can then enter your thread topic and first post.
04-27-2016, 07:04 PM #9
- Apr 2016
- North Carolina
Any reviews on the Hawks 515hp kits
04-27-2016, 08:52 PM #10
- Aug 2007
- Greensboro, NC
Pewter- 2002 Trans Am WS6 M6
Hawks is pretty good but since your in nc, guessing around cherry point based on the zip code I would hit up tick performance in Mt airy or Smallwood performance in mcleansville. Martin Smallwood used to work for tick as their cam and head guy but recently split off and formed his own company. Both are great companies and you can't go wrong with either. You can call them up and they can custom spec whatever you want or you can do one of their standard packages. Havent been to Smallwood shop yet but seen Ticks and they have all sorts of high end stuff coming and going all the time.
04-28-2016, 03:06 AM #11
- Apr 2016
- North Carolina
04-28-2016, 03:08 AM #12
- Apr 2016
- North Carolina
Have you heard of majestic motor sports in Hubert,nc
04-28-2016, 09:05 AM #13
- Apr 2010
- Alabama
No I'd use tick performance. They built my 421 stroker and Martin Smallwood designed the cam. I couldn't be happier.
Heads and Cam packages?
By Naaman in forum Internal EngineReplies: 47Last Post: 06-21-2013, 01:45 PM -
Question: cam packages?
By jholguin in forum Internal EngineReplies: 11Last Post: 07-20-2010, 11:37 PM -
suspension packages
By kosovobandit in forum Suspension and HandlingReplies: 5Last Post: 05-15-2006, 07:31 AM -
SLP cam/head packages
By trainingdragon in forum Internal EngineReplies: 5Last Post: 02-27-2006, 04:57 AM
