Thread: Antifreeze leak?
08-05-2015, 11:54 AM #1
- Jun 2014
- Connecticut
Black- 99 Trans Am WS6
Antifreeze leak?
So in my 99, I just replaced the overflow tank because it would leak antifreeze. That fixed it and the tank level is fine. Now after running hot and it cools off the antifreeze seems to disappear from the radiator without any sogns of leaks. The oil also looks perfect. Any ideas of what could be going on? Thank you
08-05-2015, 12:39 PM #2
Check your passenger side floorboard. Is it damp?
08-05-2015, 04:29 PM #3
- Jun 2014
- Connecticut
No it's not. I just replaced the radiator cap. I notice it was fitting loose so maybe there was an air leak and it doesn't have enough pressure to fill the radiator up. I'll test drive it tomorrow
08-05-2015, 05:26 PM #4
My guess is that the space you are seeing at the top of the radiator is fairly normal. It'll push fluid into the overflow when hot and suck it back in when it cools. As long as the level stays consistent I wouldn't worry about it. I would recommend though that you check both your transmission (if A4) and your power steering as they are also cooled by the radiator. Looks for any yellow/white sludge on the dipsticks -- that is a sign of water contamination.
08-07-2015, 04:42 PM #5
- Jun 2011
- Branchville, NJ
Any sweet, white smoke from the exhaust ?
antifreeze
By V8MUSCLE in forum Almost Anything GoesReplies: 23Last Post: 02-17-2010, 05:32 AM -
Leaking antifreeze
By BlackbirdRamAir in forum External EngineReplies: 2Last Post: 02-10-2010, 03:08 AM -
Antifreeze...
By guitarjay76 in forum General HelpReplies: 3Last Post: 06-07-2009, 07:27 AM -
ttop leak, hatch leak, and window motor problems
By ATCharming in forum General HelpReplies: 41Last Post: 07-23-2007, 02:30 AM -
Antifreeze smell
By repeter in forum GTOReplies: 0Last Post: 05-21-2007, 06:38 PM
