Results 1 to 1 of 1
Thread: Valve Lash In A Flash!
09-23-2014, 02:10 AM #1
- Aug 1999
- Arizona
A Little Know-How Makes Living With a Solid Cam EasyWhen it comes to transferring power or motion, the less deflection a system has, the cleaner the delivery. Solid camshafts and lifters are the key to optimizing the power output of an engine and achieving sustained high-rpm stability; we like them so much, we use them a lot in our aggressive street-engine builds. That level of precision comes with higher maintenance requirements, however.
a
Photo Gallery: Valve Lash In A Flash!
More...
excessive rear end back lash be reduced w/ hand tools?
By qwik219d9 in forum DrivetrainReplies: 44Last Post: 12-15-2014, 10:44 AM -
House Democrats in Dispair, ..Lash out at Pelosi!
By wileyCoyote in forum Political / Debate ForumReplies: 1Last Post: 11-18-2014, 09:46 AM -
JEGS stud mount valve spr. compresor vs. Speeds valve spring
By JehalinTA in forum Internal EngineReplies: 0Last Post: 05-30-2011, 05:16 AM -
Valve cover gaskets, Valve Springs, Timing Gasket
By Dewman in forum Parts For Sale / TradeReplies: 0Last Post: 01-22-2010, 08:14 PM
