Results 1 to 20 of 20
Thread: Scaled the D-max today
09-03-2013, 09:02 AM #1
Curious what it weighed compared to my old 79 1 ton.
Orion, you had mentioned your Dmax doesn't stop very well, as well as a friends Dmax. I mentioned I'm experiencing the same thing. Might have something to do with the weight of the truck.
This is a 2500HD crew cab short bed 4x4.
With a full 26 gallons of fuel, no driver/passenger, 33" tires, and an aftermarket exhaust (that certainly lightened it up), and it still scaled 6,845 lbs.
So with one decent sized person it's already over the 7,000 lbs. mark. It definately has some girth. Hard to imagine with all the plastic stuff they put on these cars nowadays.
For comparison sake, my 79 1 ton with a big block/auto, long bed 2 wheel drive and 1/2 tank of fuel (20 gallons) scaled at 5,230 lbs without a driver.
09-03-2013, 09:10 AM #2
WOW...i wonder what my Avalanche weighs?
09-03-2013, 01:41 PM #3
Suburban tips in at 6,200 lbs and our Durango was 5,200 lbs.
09-03-2013, 04:26 PM #4
- Apr 2008
- Madison, WI
That shouldn't surprise me, but it does a little bit. But I guess it makes sense. The dealership I work at used to sell Hummers. And we couldn't lift the H2s on our old 7000 pound hoists if they had a couple accessories like aftermarket wheels and bulky brush guards. Which means, those short wheel-based, "3/4" ton chassis/axle, 6.0 gas V8s, H2s with factory 35s were weighing close to 6500 to 6800 pounds stock.
And the tree-huggers were pissed off. Mean while all the trucks running around were weighing the same and getting the same crappy gas-mileage.
I hate people.
09-04-2013, 05:02 AM #5
09-04-2013, 05:10 AM #6
Not surprised at the suburban, they aren't small vehicles, but that Durango is a bit of a shock at 5,200. Those aren't that large, and I've rented them before when on vacation, they don't drive like a 5,000 lbs. vehicle.
Considering that's as much as my 79, and it has big heavy stuff in it. Large 10.5" ring gear 14 bolt full floater rear, big block chevy and 400 turbo, dual gas tanks, even the wheels are overkill compared to other trucks of that vintage. Darn steel wheels are so thick I have to modify wheel weights to knock them on the bead when balancing the tires. 16.5" diameter and they weigh 65 lbs. a piece, Not to mention the whole truck is made of steel.
09-04-2013, 07:03 AM #7
I already knew mine was in the 7500 lb range. Makes the 20+ mpg even more impressive. I've always blamed the shitty brakes on the whole power steering brake boosted set up. I don't really understand it or know anything about it. I know why they use it but it's the first vehicle I've had like that. The dodge diesel trucks are heavier than ours & stop much better.
We also had an 05 Durango & you're right.....it doesn't drive like a heavy vehicle & oddly enough ours got pretty decent mileage even with the gas guzzler 4.7 in it. Much better than the trucks. I'm guessing gearing played a big part in that. The dodge truck probably has 3.73 or 4.11 rears & the durango had 3.55'sLast edited by 0rion; 09-04-2013 at 07:06 AM.
09-04-2013, 07:55 AM #8
[QUOTE=Cutlass;2863000] The dealership I work at used to sell Hummers. And we couldn't lift the H2s on our old 7000 pound hoists if they had a couple accessories like aftermarket wheels and bulky brush guards. [QUOTE]
I just noticed this. I'm surprised a dealership would even install the little 7,000 lbs. lifts, especially since they sell Hummers.
09-04-2013, 08:01 AM #9
Yep I was thinking the same thing, 20 mpg and over 7,000 lbs. is pretty damn impressive.
I actually like the hyrdo-boost brake system. It's flawless on my old 79 1 ton and stops on a dime. I even added hydro-boost to the chevelle because the engine didn't make enough vacuum and an extra vacuum canister wasn't cutting it.
I tend to blame the shitty D-max brakes on the smallish disc brakes all around. They could stand to be a lot bigger considering the size and girth of that truck, especially the rear. Disc pads just don't have a large contact surface area. Only way to improve it is larger diameter rotors and larger calipers.
09-04-2013, 12:04 PM #10
what size rear is on that thing? Not going to ask why they have such small rotors/calipers.
09-04-2013, 12:11 PM #11
09-04-2013, 12:48 PM #12
After driving my Dad's Dmax truck a couple days back, I'd easily bet on it stopping waaaaaay shorter than any 79. It stops just fine, and the calipers and rotors on that thing are massive IMO. It's a regular cab, long bed 2500 though, so definitely lighter weight than any of the crew cabs, etc. It also has over 50K miles on it, and shows almost no discernible brake wear from new.
09-04-2013, 03:17 PM #13
WOW thats a tank.
My TA weighs 3700 with a full tank of fuel the 5th Gen weighs 3950 with a full tank of fuel.
So your truck is not far off the weight of both my cars2010 Camaro SIM 2SS/RS A6
1999 TA A4 NBM
12.265 at 110.52mph
09-04-2013, 05:27 PM #14
- May 2010
- Wilkes-Barre, PA
Black/Black- 98 WS6/04 Sierra Dmax
My Dmax seems to stop just as good as my 04 Tahoe, both sporting hydroboost. The Dmax will also run circles around the Tahoe Friend of mine said his 2005 Dodge 2500 with a cummins and a M6 hit 7,200 on the scales.
09-05-2013, 03:21 AM #15
09-05-2013, 03:38 AM #16
Suburban with the 5.3 and DOD will pull almost 18 on the highway. Hook up the trailer and that drops to around 9.3 mpg.
09-05-2013, 05:07 AM #17
09-05-2013, 08:03 AM #18
- May 2010
- Wilkes-Barre, PA
We have a 8,000 pound two post and a 10,000 pund 4 post in our garage. So far they both picked up everything I threw at them.
Callies 383, Trick Flow 225, Rapid Motorsports Dominatior 2 X cam, ls6 ported oil pump,42lb injectors, FAST 92/92 , ASP underdrive pully, eletric water pump, Pacesetter LT's, Pacesetter ORY, Magnaflow catback, e-cutout, Yank SS 3600, Performabuilt stage 2 4l60e, Strange S60 ,4.10s, Detroit Truetrac, (UMI) - Adj. LCA, Adj. tunnel mount torque arm, Adj. panhard bar, Drag bar, subframe conectors, shock tower brace. 465rwhp-438rwtq 11.09@119.90.
09-05-2013, 09:38 AM #19
Mine is only rated for 7,000 lbs.
09-05-2013, 02:39 PM #20
ss put it on a 5.0 today
By SSIZZLN in forum Kill StoriesReplies: 9Last Post: 06-20-2011, 03:13 PM -
I had a lil fun today
By Pony_Eater in forum Almost Anything GoesReplies: 3Last Post: 02-25-2009, 04:23 PM -
What I saw today
By snuffster in forum Political / Debate ForumReplies: 7Last Post: 11-07-2008, 07:43 AM -
ran car today
By aquickfive0 in forum Forced InductionReplies: 7Last Post: 05-09-2006, 12:02 PM
