Thread: Clutch pedal
08-29-2012, 04:39 PM #1
- May 2012
- Liverpool ny
Clutch pedal
Anyone have any problem with their clutch not coming all the way up?? It only happens when I really get on it out of the hole. I have to pull it back up from behind .
09-03-2012, 07:18 AM #2
09-03-2012, 07:23 AM #3
- Jun 2011
- Branchville, NJ
09-03-2012, 08:27 AM #4
- May 2012
- Liverpool ny
It's kinda dark, car only has 20k on it, is that around the mileage it should be changed?
09-03-2012, 01:54 PM #5
- Mar 2009
- pompano beach florida
- 2002 Camaro Z/28 Pewter
The fluid should be changed when it gets dark but that most likely wont alleviate the problem. The master is 10 years at least and is probably leaking inside under a hard launch. My advice is look into a tick master cylinder it is 300 bucks but its leap and bounds better than a stocker. also keep in mind that the master MAY not be the issue although with only 20k on the clutch I doubt its the PP. Do this test go underneath the car and disconnect the master cylinder line at the slave cylinder. Now go back in the car and press the clutch pedal, it should feel rock hard and should stay that ay even if you put pressure on it with your foot when you do this if the pedal starts to fall towards the floor the master is def toast. make sure also when you do replace the master that you do a complete fluid flush to get all the old fluid out of the slave
Clutch Pedal Pressure and Smelly Clutch
By race5050 in forum Manual TransmissionReplies: 1Last Post: 01-06-2010, 05:37 PM -
Help: Clutch Pedal
By Ghawk996 in forum Manual TransmissionReplies: 9Last Post: 09-11-2008, 11:08 PM -
Light Clutch Pedal (New Clutch)
By Rhinohuey in forum Manual TransmissionReplies: 2Last Post: 09-22-2007, 08:51 PM -
By Rhinohuey in forum Manual TransmissionReplies: 5Last Post: 09-14-2007, 02:41 PM -
Fading Clutch Pedal with new clutch
By mrbob2 in forum Manual TransmissionReplies: 2Last Post: 08-17-2007, 05:58 PM
