Results 1 to 13 of 13
    Member pv-camaro's Avatar
    Dec 2008
    Netherlands (europe)
    Light Pewter (11)
    2001 Camaro
    Replacing bubbling rooftop panel
    Hi,
    It looks like mine 2001 Camaro (T-tops) is creating some bubbles on the roofpanel.
    I think it needs to be replaced, GM has stopped making these panels.
    I'am thinking of buying a panel from 6LE Designs, or is it a better option to remove a panel from a pre 98 donor car, the original panel is ABS plastic (if i am correct) and the 6LE is fiberglas ?
    Has anyone already tried this panel 6LE designs ?
    How is the fitment, will it fit just like the original one ?
    Oct 2009
    The Woodlands/spring/houston
    pewter
    99 trans am
    not sure of the fitment....i know the cost is around $600....the "glue" used by gm is what caused the bubbling....i have yet to see anyone use the one from 6le..
    i believe pajeff has a thread about this situation...
    Quote Originally Posted by jiveass View Post
    john, think of the ls1 as the chuck norris of all engines....there isnt a bearing on earth that can stand up to its huge cock of a rotating assembly....its just that bad ass....besides..even with my engine out, i can still smoke your ford....
    http://i171.photobucket.com/albums/u317/v8mike/tpb.gif
    Yes...this engine wanted to take a break from kickin ass so that it can pursue a career in acting..but will soon realize that no one will hire it due to it being so bad ass, and thats a liabiliity....
    Dec 2008
    Light Pewter (11)
    2001 Camaro
    the costs are not the problem, the orginal one is just as expensive
    I am just a little bit worried about the fitment, and will it look just as the orginal one.
    I have had a 71 Camaro for several years, and had to replace most of the intior parts with "repo" parts, and some just won't fit.
    Member 02fbody35th's Avatar
    Feb 2008
    scranton,pa
    2002 camaro 35th anv.
    I asked the same question a couple months ago and the panels were still in pre production, I believe this is still the case so know one actually has one yet. but I too was worried about the fitment so i got one off a pre 98 car in the scrap yard. not an easy task. but if you would like i can let you know how I went about getting it off.
    phoenix
    04 2500 4x4 crew cab
    You should share it here. I have heard that it is impossible to get off wo breaking it.
    Dec 2008
    Light Pewter (11)
    2001 Camaro
    In februari i went to a yunkyard, and tried to get it of a 94 Firebird.
    It didn't work, maybe it was to cold and the glue was to thick.
    I used a thin iron cord
    Feb 2008
    scranton,pa
    yeah its imposible to get thru the glue without heating it up, what i did was have the junk yard cut off the roof section where the panel is. then i loaded it into the back of my suv and when i got it home i cut as much metal from the underside as i could in order to reach the layer of metal where the panel is actually glued to. then I heated it from the underside with a heat gun, once the glue was warm enough i used a piece of heavy gauge guitar string and it went thru like butter. now dont get discouraged at the begining because on the bottom portion of the panel where it meets with the quarter panel is gonna be where you first enter with your wire and there is alot of glue there, so its gonna be tough at first. but once you get thru that section its smooth sailing. you may be able to heat the panel from the outside if you dont feel like having it cut off and bringing it home but you would have to be very careful not to damage the panel, im not sure though because i didnt do it this way.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    I overheard a discussion at Carlisle with friends about the removal method. I can't remember if one friend talked about using a curved tool like a hooked knife to remove the old panel.
    phoenix
    Would painting the panel stop it from bubbling? I plan on painting mine. And I dont have ANY bubbling now. It sits in the garage.
    North Jersey
    2004 GTO M6
    Quote Originally Posted by az gt eater View Post
    From what I have read on this forum and heard from friends who own F-Bodies, if the bubbling has started on the current panel, the panel is toast and needs to be replaced. GM has either changed or reformulated the adhesive so it won't seep through the replacement panel. I think there are members who removed the panel and glue and just painted what was underneath.
    Dec 2008
    Light Pewter (11)
    2001 Camaro
    I went to a guy who takes Firebirds (mostly totaled by a crash) apart, and i bought a roofpanel from a 1996 Firebird.
    They removed the complete roof for me, for € 100,00 (about $ 135,00).
    At home i took a paint stripper, and heated the underside of the metal roof, so the adhesive gets soft a litte bit.
    I took some cutting wire, and removed this panel without a problem.
    One the side of the window panels (T-roof) you have to bent the metal, so it's easier with the cutting wire.
    The complete roof:
    Cutting wire:
    The panel is removed:
    The metal you have to bent, for easy acces with cutting wire.
    The underside of the good panel,
    Only i have to remove the rest of the adhesive:
    My 2001 Camaro has a few little bubbles (no damage to the paint), so i don't remove my roofpanel yet, but now i am sure, when the time has come, i have a good panel, so i can solve this problem.
    I think this is a much cheaper sollution than a new repro panel, and the car stays orginal , and it fits exactly.
    Junior Member prater_1's Avatar
    Sep 2009
    Ft. Worth, Texas
    2002 Z/28
    What about on a hard top?? I have the bubbles all around the roof and now they are starting on the sail panel!!
    Member cancam99ss's Avatar
    Apr 2010
    Miami
    Navy Blue
    Chevrolet Camaro SS
    I have to do. This!!! I just plastidipped the roof
  1. Bubbling sail panel
    By SS Camaro UK in forum General Help
    Last Post: 11-01-2013, 01:40 AM
  2. need help with bubbling in paint
    By WHITE TA in forum Appearance Section
    Last Post: 02-15-2012, 10:14 AM
  3. Help: bubbling on my '01 trans am
    By '01 ws6 som in forum Appearance Section
    Last Post: 06-04-2011, 09:30 AM
  4. Question: Replacing sail panel speakers
    By California Kid in forum Stereo and Electronics
    Last Post: 11-08-2008, 10:00 AM
  5. Sail panel roof bubbling.
    By TA421 in forum General Help
    Last Post: 03-30-2008, 07:33 AM
