Thread: what size?
12-29-2010, 01:16 PM #1
- Oct 2009
- The Woodlands/spring/houston
pewter- 99 trans am
what size?
what size is the stock exhaust on a 99 trans am...after the y pipe that is...i need to know because i got an idea brewin for a y-pipe...
12-29-2010, 05:18 PM #2
- Apr 2010
- Alabama
Why don't you just buy a y-pipe instead of jury rigging something together?
12-29-2010, 05:35 PM #3
- Oct 2009
pewter- 99 trans am
Because if I can do it cheaper then that's what ill do. Money is tight at the moment and I need somethin to do anyway.
12-29-2010, 06:07 PM #4
Can you do it cheaper than a new off road Y-pipe offered from Texas Speed? Because they have one listed on their site for $129 marked down from $149.
Pretty darn cheap if you ask me.
12-29-2010, 07:01 PM #5
- Apr 2010
- Alabama
If money is tight I would just wait until you have the money to get a proper y pipe instead of jury rigging one.
Like Firebirdjones said that is really cheap for a y pipe, I doubt you can build a proper y pipe cheaper than that, I would get the TSP pipe if you are looking for a cheap but good quality y pipe. You really don't want to cut corners on your exhaust because you will probably end up having to replace it again when it falls apart and end up paying more than just doing it right in the first place.
12-29-2010, 07:14 PM #6
I want to know what this idea brewin' is.
12-30-2010, 03:36 AM #7
- Oct 2009
pewter- 99 trans am
i can see you guy's point, and yes that is a good price for a y...but like i said, i have an idea on how to do it cheaper....you cant just assume that its gonna be a shitty setup when i havnt even told you about it....i just wanted to know the stock exhaust size where the y pipe connects to. the size of the pipe will determine if im even gonna fool with it or not. c'mon fellas, a lot of people try things and fail, and some succeed...thats what the gear head life is all about...
12-30-2010, 05:05 AM #8
- Apr 2010
- Alabama
What I said may have come out a little harsh. I just would hate for you to try to do this and end up spending more money in the event it doesn't work. What is your idea any way?
12-30-2010, 06:23 AM #9
- Oct 2009
pewter- 99 trans am
i found a y-pipe thats actually meant to turn a single exhaust into dual exhaust....its got 3" on the dual side and 2.5 on the single outlet. i can get it for basically nothin...brand new stainless steel....i figure id get it and toy with it to see if it would work....its a longshot but its cheap enough to be worth a try.
12-30-2010, 07:24 AM #10
12-30-2010, 07:35 AM #11
12-30-2010, 04:29 PM #12
- Oct 2006
- St. Clair Shores. Michigan
Well since no one else said it the stock I pipe is 2.75"
Craig
Semi Retired Street Racer
Gone but not forgoten
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
LS1 valley cover bolt size, what size?
By Blue28 in forum External EngineReplies: 1Last Post: 10-03-2009, 05:47 PM -
Help: Cam size help
By Sarge91 in forum Internal EngineReplies: 15Last Post: 06-21-2009, 09:07 PM -
Question: What size wheel studs? OEM size?
By x10-wakerider in forum Wheels and TiresReplies: 2Last Post: 06-20-2009, 08:26 AM -
what size cam?
By MCCs WS6 in forum Internal EngineReplies: 7Last Post: 06-29-2007, 05:42 PM -
What size?
By clg82 in forum Wheels and TiresReplies: 2Last Post: 06-11-2007, 03:10 PM
