Results 1 to 11 of 11
Thread: looking for rear wheel axle
08-11-2010, 03:58 PM #1
If anybody has a stock rear axle let me know
I only need 1
08-12-2010, 06:32 AM #2
- Aug 2009
- VA
- iTrader
- 0
WHITE- 98
I haue two $50..each
08-12-2010, 09:59 AM #3
- Jun 2008
- Euclid,ohio
- iTrader
- 0
Black- 1998 Z28
for 3 channel ABS or 4 channel ABS & TC/ASR ?
they're different and not interchangeable.
you need to specify for which !
08-13-2010, 03:11 AM #4
How do I find out which 1 is it ?
Thanks in advance
08-13-2010, 04:52 AM #5
- Jun 2008
- Euclid,ohio
- iTrader
- 0
Black- 1998 Z28
if your car has traction control(ASR button/switch above radio/below vents),you have 4 channel,if no ASR button/switch it's 3 channel.
08-13-2010, 07:19 AM #6
- Aug 2009
- VA
- iTrader
- 0
WHITE- 98
I got 3 channel in va
08-13-2010, 06:22 PM #7
damn I need the 4 channel cause it has an asr button
thought I found 1 ..
thanks guys
08-18-2010, 03:05 PM #8
- May 2007
- Chas. WV 25303
- iTrader
- 2 (100%)
WHITE- 2002 Z28
4 channel axle
I have a 4 channel axle for $40.00 and $25.00 shipping. no exciter ring with the axle. pleaswe PM me if interested. thx
08-19-2010, 02:53 AM #9
What is exciter ring ? Do I need it ? Sorry not familiar with that...
08-19-2010, 03:10 AM #10
- Jun 2008
- Euclid,ohio
- iTrader
- 0
Black- 1998 Z28
the exciter ring is the piece in the above picture in post #5 that looks like a gear that is pressed on the axle. sometimes difficult to press/remove off/on. necessary for 4 channel operation.
08-19-2010, 08:46 AM #11
- May 2007
- Chas. WV 25303
- iTrader
- 2 (100%)
WHITE- 2002 Z28
exciter ring
the exciter ring should be able to be removed from your existing axle. with heat added, it should come right off. my axle had exciter rings previously and a mechanic shouldn't have any difficulty with all of the installations.
Help: Is this rear axle bad?
By JayTA98 in forum General HelpReplies: 17Last Post: 02-12-2015, 01:33 AM -
Rear axle
By juanZ28 in forum DrivetrainReplies: 22Last Post: 05-04-2011, 02:04 PM -
rear axle need help
By drago1217 in forum DrivetrainReplies: 6Last Post: 04-30-2010, 02:40 PM -
new rear axle
By barryz in forum Manual TransmissionReplies: 0Last Post: 07-25-2008, 10:48 AM -
Rear Axle/Rear Grear Problem
By ob02z28 in forum Manual TransmissionReplies: 0Last Post: 01-22-2007, 10:32 AM
