Results 1 to 13 of 13
    NYC
    2000 T/A Firehawk M6
    Next Gen Small Block
    It's not much but it's something.
    GM is investing $900M in their V8 program for the Next gen small block. Small quote with the only meaty bits of their press release:
    "The next generation small block engine family will have unprecedented fuel efficiency through direct injection and an all-new advanced combustion system design. The new engine family will rely exclusively on aluminum engine blocks, which are lighter and contribute to the improved fuel efficiency. In addition to being E85 ethanol capable, these engines are being designed with the capability to meet increasingly stringent criteria emissions standards expected throughout this decade."
    No specs on power or displacement. I'm sure it'll come in time. Maybe these will be out in time for my engine swap and I can get one of these with a new ECU for my car. Till such time as that proves possible I'm still eyeing that LS3. mmmmmm.... LS3
    alabama
    Gray
    2012 Challenger R/T
    can you say small CID and TT??
    Wisconsin Rapids, WI
    1999 Z/28 M6
    that would still be pretty interesting though. something like a a sub-5.0L engine...short stroke TT...so you'd have a high revving high horsepower v8 which could make power along a huge powerband. tell me that that's not kickass.
    NYC
    if by kickass you mean 1980's formula 1 kickass then yes... indeed it is. but if by kickass you mean american burbling small block "there's no replacement for displacement" kickass..... then no.... no it's not....
    park bench
    gmcheviac
    They need to stop going up in displacement as far as mileage for sure. This will probably be 5 liters at best
    Omaha, NE
    2000 Z28 Camaro
    I think their mileage is good considering their displacements.
    park bench
    gmcheviac
    didn't say it wasn't. I said they need to stop going up
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    The displacement wars won't stop rising. GM has the 572, Ford has the 615(I think) and Mopar has the Mammoth 526 Hemi.
    park bench
    gmcheviac
    those were never put into production cars affected by cafe standards. I'm talking about the progression from the '97 5.7 -> '05 6.0 -> '08? 6.2. That might be a negligible difference in performance between those from displacement only, but it's not going to help mileage
    Also, you're a little low with your cubic inch numbers on mopars and bbc's people build way bigger
    North Jersey
    2004 GTO M6
    That is true. As of now, isn't the largest displacement production motor the 427/LS7? I wonder if there will be a production 454/455 in the upcoming Camaros?
    park bench
    gmcheviac
    currently yes. I don't forsee a 455. Gm skurred. Not a huge gain on emissions engines i'd imagine with crap manifolds, a limp dick cam, and multiple cats. Also the longer stroke won't last as long and is more likely to consume oil
    North Jersey
    2004 GTO M6
    But is sure would be nice to see a fifth, sixth, or seventh gen Camaro with a 455SD in it. Oh how I dream.
    Wouldn't it need to bring back Pontiac before it created a 455SD again? It would be nice to see a 454 back in the Camaro though, even though the big block is dead.
  1. Chevy Small-Block, Big-Block & Transmission Buildi
    Last Post: 11-20-2009, 01:50 PM
  2. Small block mains
    By TexasLS1 in forum General Help
    Last Post: 02-18-2009, 09:55 PM
  3. Small Block Conversion To Big Block
    By Ronald Nora in forum General Help
    Last Post: 05-03-2008, 05:51 PM
  4. Small Block Sophmore
    By bladerunnerss in forum New Member Introductions
    Last Post: 12-16-2006, 02:09 PM
  5. WTS: Small block blower set up
    By heckinohio in forum Parts For Sale / Trade
    Last Post: 11-21-2006, 09:31 AM
