Thread: Rockers
03-25-2010, 12:12 PM #1
- Mar 2010
- Oak Lawn/ Chicagoland
Yellow- 2004 GTO
Rockers
Hey I'm new here ! so I have 2004 GTO and I need some info on rockers my GTO only got 24k on it and i hear some Valve Train noise ,So i got some Rockers from Summit Racing 1.8 ratio should be here in a few days and im going to ck my push rods as well any input Please!!!!!!! I have seen the roller bearing coming apart on the stock rocker
03-25-2010, 05:26 PM #2
- Jun 2009
- coon rapids, MN
red- 2000TA
I got some yella terras at KY Speed for $409.Is that the correct stock ratio? Most people just up grade with better bearing from harland sharp or compcam.consider getting a push rod checker,and you mite need better push rods if you are changing the ratio.Have you been to the GTO forum ?
03-26-2010, 06:29 AM #3
- Mar 2010
Yellow- 2004 GTO
Yes I have and thank you some realy good info there eg: like the extra mods with the set and mode button i own my car from new and i'm a GM Tech and never knew about it lol my car is still storage over the winter soon as i go up there to get it out i'm going to mess around with it again thank you very much
03-27-2010, 03:44 PM #4
- Mar 2008
- OHIO"S only 9 second GTO
Phantom Black Metalic- 2005 GTO
the ls motors are notorious for valve train noise,my 99 silverado sounds like a diesel when its cold,im still using the stock GM rockers,rev mine to 7800 in the GTO,its also alil loud,at idle when cold. dont think the noise is the rockers, rather think its the stock lifters,GM has upgraded those and they have gotten better.
Rockers
By andyramsaran in forum GTOReplies: 0Last Post: 03-25-2010, 12:02 PM -
are 243 OEM rockers the same as 853 OEM rockers
By qwik219d9 in forum Internal EngineReplies: 1Last Post: 12-29-2009, 12:30 PM -
Rockers
By phoenix1987 in forum Internal EngineReplies: 12Last Post: 09-08-2006, 02:11 PM -
1.8 rockers
By Ratdaddy07 in forum Internal EngineReplies: 12Last Post: 05-31-2006, 10:34 AM -
rockers
By jay_7681 in forum LT1Replies: 4Last Post: 08-14-2005, 06:44 AM
