Results 1 to 1 of 1
05-19-2009, 01:40 AM #1
- Aug 1999
- Arizona
Small-Block Chevy Build - Cheap 350 Phase 2
We put last month's dirt-cheap, parts store 350 back on the dyno with more compression, better heads, and a new cam and kick the grunt up to 420 hpHot Rod recently assembled an economical 0.030-over 350 Chevy based on a Coast Motor stock-replacement-style short-block that made 391 hp when equipped with GM iron Vortec heads, a Comp Cams hydraulic flat-tappet oval-track cam, an Edelbrock Performer RPM high-rise dual-plane intake manifold, affordable Summit Racing 1 5/8-inch primary-tube headers, a GM HEI distributor, and a Holley 750-cfm vacuum-secondary carburetor (see HOT ROD, May '09, "Cheap 350"). The whole package came in at just over $2,600, a real boon in today's tight economy. But 391 hp, although certainly no slouch in the power/dollar department, was still shy of our original 400hp goal. This month, we decided to bring the Cheap 350 back with some alterations in an attempt to blow past the 400hp mark without shelling out cash like a drunken sailor on shore leave. We raised the compression ratio, changed the cam, installed RHS Pro Torker heads, and finally revisited Edelbrock's Super Victor Vortec intake.
Photo Gallery: Small-Block Chevy Build - We Increase The Cheap 350's Grunt To 420 HP - Hot Rod Magazine
More...
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 04-17-2009, 10:40 AM -
Whipple Supercharger 383 Small Block Chevy Build -
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 11-24-2008, 07:10 PM -
Chevy 355 Small Block Engine Build - Cheap Skate!
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 10-28-2008, 07:20 PM -
383 Chevy Small Block LS1 Engine Build - LS Resurr
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 10-17-2008, 06:10 PM -
327 Small Block Chevy Engine Build - The 500HP Que
By Ed Blown Vert in forum Camaro / SSReplies: 3Last Post: 10-09-2008, 08:15 PM
