Thread: eibach springs???
01-13-2006, 12:12 PM #1
eibach springs???
wonder if anyone with these springs noticed if the inside edge of the front tires got worn excessively......they did in my car it might have been the tires were unbalanced
01-14-2006, 05:36 AM #2
let me guess, you put the springs in and didn't get an alignment done? anytime you raise/lower a vehicle, it changes the alignment. in your case, lowewring the car made the camber and toe more negative. meaning negative camber = tires leaning inward from the top more when viewed from the top. negative toe = tires point outwards when viewing from the front. all this causes the tires to wear from inside to outside.
01-14-2006, 07:12 AM #3
- Nov 2005
- Knoxville,Tn
Black- 1999 Pontiac Firebird
Ditto, check your Camber.
01-23-2006, 06:08 AM #4
- missouri
Artic White- 2002 Ws6
same thing
I also lowered mine with the same springs and yes you have to get an alignment.
01-24-2006, 11:48 PM #5
- Jun 2002
- Montreal, CANADA
get an alignment and make sure you get a printout of the given specs.
Go with the GM except for the camber... try getting a bit of negative camber instead of positive camber... will make for better wear/grip.
GM did that to induce understeer on the cars, and it makes the outside edge of the tires go bald.Eugenio_SS
01-29-2006, 03:50 PM #6
yea, I have the eibach sportline 2'' lowering kit with bilstein shox. Everything was done in a garage except the alignment. You must have your wheels alingned when ever you mess with that. I must say that the eibach bilstein combo is great, im loving the handling of my car. Only downsides are clearance issues bumpy ride.
For Sale: eibach springs
By 99yellowz28 in forum Parts For Sale / TradeReplies: 4Last Post: 02-15-2011, 05:49 AM -
want eibach pro kit springs for 01 Z28
By karpetcm in forum Parts Wanted / TradeReplies: 2Last Post: 10-28-2008, 07:05 AM -
eibach springs
By itsfess in forum Suspension and HandlingReplies: 6Last Post: 05-27-2008, 08:05 AM -
f/s eibach pro kit springs...
By barnac0 in forum Parts For Sale / TradeReplies: 0Last Post: 04-11-2007, 06:22 AM -
Eibach Springs
By mike44 in forum Parts For Sale / TradeReplies: 3Last Post: 12-09-2005, 01:06 AM
