    Alabama
    Exclamation Push Rod Length for 383 Stroker...Help!!
    Just got my 383 running and after 90 miles of break in I had about 4 push rods bend.. Talked to the guy that built my motor and he gave me the wrong size.( stock Ls1 7.400). I checked the gap under one of the good pushrods rocker arms to the top of a released vavle and it was not even .010 and the guy said it needed to be between .040 and .065. What pushrod do I need to go with to solve the issue..? 7.325 or 7.50? I can do the math but was going to see what others thought.
    98 Trans Am
    383 Stroker-Eagle Crank, Pistons, Custom Ground Cam, Z06 valve springs
    6-speed
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    off hand i dont know. you can buy/borrow/ rent an adjustable length pushrod and find out pretty easy.
    You used stock pushrods? Not hardened ones??
    What valvesprings?
    What heads? What cam? Heads milled?? What lifters?
    Lowered, HID's, tinted.
    Florida
    1999 TA WS.6
    oh no... gotta get get some good chrome molly hardened pushrods or something.
    RI
    Mag Red
    2002 Vette
    Are you running solids or hydraulics? It sounds like you are measuring clearance between the rocker tip and the valve stem like a solid roller setup.
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    At least a 0.80" WALL
    You need to get a adj. pushrod to figure out what length you really need!!!!!
    You have to spin the motor over and watch what the rocker is doing compared to he valve tip.....You don't want it to walk all the way off the edge and you don't want it to start on the edge.......
    NO ONE WILL BE ABLE TO TELL YOU WITH OUT DOING THIS!!!!
    EVERY MOTOR IS DIFFERENT....HEAD GASKET THICKNESS,HEAD MILLING,AND CAM WEAR ALL EFFECT CORRECT LENGTH.
    I ALWAYS RUN SMITH BROTHERS.....AWSOME PRODUCT AND SAME DAY TURN AROUND!!!
    Hope I helped.
    Florida
    1999 TA WS.6
    Quote Originally Posted by LS2Tuner View Post
    Hope I helped.
    Listen.
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    O'h Whatta.....
    Listen.
    Couldn't hear you........
  1. How to Measuring for Correct Push Rod Length.
    By SMWS6TA in forum Internal Engine
    Last Post: 01-14-2023, 11:24 PM
  2. stock push rod length?
    By third_shift|studios in forum Internal Engine
    Last Post: 05-08-2012, 08:07 AM
  3. Push Rod Length
    By meathammer in forum Internal Engine
    Last Post: 03-25-2011, 03:56 PM
  4. How To Check For Proper Pushrod Length - Push It -
    Last Post: 09-28-2009, 10:20 PM
