Results 21 to 40 of 90
Thread: LQ4 Turbo Build Thread
05-11-2012, 08:18 PM #21
o im sure its one of the best but i really like AEM's new setup and have a buddy running it on his rear mount setup....
Pictures will be coming as parts are bought/come in.... nest on the list is piston rings, ls2 timing chain, ls7 lifters.... anything to get the bottom end together!!!
05-16-2012, 05:45 AM #22
I told you guys this is going to be a slow process!!!
But, I just got my clevite rod and main bearings in, Total Seal piston rings that better be on their way, and ARP rod bolts...
I also ordered LS7 Lifters and LS2 Timing Chain.
Still looking for LS1 oil pan, windage tray, and pickup tube. But, I can get the windage tray and pick-up tube new for under $50, just trying to save some cash but the pan is almost a must, but dont want to spend $150+ on one!
05-16-2012, 07:12 AM #23
Kyle
I started a thread in another section but was wondering if you might be able to answer some of the questions I have in it since you are much further down this road then I am.
Here it is.
http://www.ls1.com/forums/f7/needing...-build-165856/
05-17-2012, 05:21 PM #24
Here is some more of a tease for you guys and for me!!! Once the Piston rings show up the bottom end is going together!
Clevite Rod and Main Bearings
LS7 Lifters
LS2 Timing Chain
and ARP Rod Bolts!
05-17-2012, 07:56 PM #25
05-30-2012, 01:15 PM #26
Not much progress at all got the cam, crank(also plasti-gauged it) and timing chain on... but have to remove the chain to replace the cam retainer and need to buy new cam gear bolts because i lost them on disassembly... working on filing piston rings to get pistons installed!
06-15-2012, 07:01 PM #27
got some more done!!! Ended up replacing the Main Cap Bolts with new OEMs.... never realized how "fun" filing piston rings is... Got piston rings finished and installed into the block with properly stretched ARP bolts. Got ARP cam gear bolts installed and installed Melling high volume oil pump #10296...
Next on the list is to finish the long block....
Parts needed: Pushrods, Valve Springs, Windage Tray, Pickup Tube, LS6 Valley Cover, and Gaskets
06-16-2012, 06:21 AM #28
Looking good!
07-04-2012, 06:19 PM #29
Still working slowly on this paycheck to paycheck got valve springs(patriot xtreme dual valve springs), comp pushrods, and now a 4l80e(got for a deal!)
next:
ARP head studs
ls9 head gaskets
full gaskets for engine
4l80e jake performance stage II rebuild kit
and turbo parts!
Valve springs!
Pushrods
Beast 4l80e! got for a DEAL!
07-07-2012, 06:44 AM #30
Progress is progress. Looks good so far and nice find on the trans. Will our PCM interface with the "80" without any issues?
07-07-2012, 08:02 AM #31
I think u need to repin the connector but other than that it should be a plug and play swap...
07-07-2012, 10:38 AM #32
- Mar 2011
- Waynesboro, Pa
Mystic Teal Metallic:320c- 1998 Camaro Z/28
awesome progress so far. keep up the good work
07-12-2012, 11:34 AM #33
Got ARP Head Studs, LS9 Head Gaskets and what not...
Here is where I am at!
Cleaned up Valve Covers
LS9 Head Gaskets
ARP Head Studs installed
LS9 Gaskets on
Heads on
Rockers on
Valve Covers on
Next on the list.
LS6 Valley Cover
LS6 Intake
Fuel injectors and rails!
Windage tray
Pickup tube
Gaskets!
07-12-2012, 01:32 PM #34
How are you going to re-install the oil fill tube? I thought that thing was bonded to the rocker cover.
07-13-2012, 02:25 PM #35
there is just a clip inside of it that you have to pry up alittle as you twist it out... so im going to take off my old one and twist the new one back on!!! :P
07-16-2012, 04:06 PM #36
Wish I had known that when I polished my stock rocker covers. I was of the understanding that it can't be removed without breaking in. Got a pic of the clip and removal method?
07-17-2012, 10:42 AM #37
I dont have a picture my self but i found this one on the internet.... you need to remove the cover to do this but there is a tab in there that you need to pry up alittle as you twist the filler neck out...
07-17-2012, 02:05 PM #38
Thanks! Now I know how to remove one in the future.
07-17-2012, 02:51 PM #39
- Oct 2009
- pasadena md
- Blog Entries
- 2
Black- 2002 SS Camaro
Good work looks sexy as usual. You going to pain the block any color?
07-17-2012, 07:45 PM #40
thanks and yes i painted it black, lol i just wanted it to be plain because ill have other stuff to be showing off
Lq4 turbo build
By 91lq4camaro in forum Forced InductionReplies: 4Last Post: 05-20-2019, 07:42 AM -
Turbo build help
By 200z28ss in forum Forced InductionReplies: 2Last Post: 02-19-2012, 04:11 PM -
My turbo ls2 build
By blackmagicturbo in forum Camaro / SSReplies: 68Last Post: 06-15-2011, 06:26 AM -
Turbo V8 Build
By SmallBCS10 in forum Forced InductionReplies: 2Last Post: 06-08-2011, 01:21 PM -
turbo ls1 build
By turbols1317 in forum General HelpReplies: 27Last Post: 09-27-2010, 08:40 PM
