Results 1 to 1 of 1
08-15-2022, 08:33 AM #1
- Oct 2006
- OREGON
4L60e TTC slip code,could use some expertise.
2012 Silverado 4L60E TCC help needed P0741
Recently bought this truck with 99k mi. trans has clean fluid,pan was clean,im sure it was off not to many miles ago.Before I put a converter in it,im reaching out here for help or advise,I pulled the valvebody off to see if TCC valve was stuck,all valves moved freely,I OHMs tested the PWM TCC solenoid and the converter on/of solenoid both in spec.
I have usedthe HP tuners tool to apply the TCC,when cold it takes about 8 seconds to come on and kill the engine.After its been running around 20min+ I apply the TCC at idle in gear,it does nothing it wont kill the engine.Here is a log,does anyone know what has to happpen for TCC MODE for it come on?Thanks in advance.
I have a log,trying to figure out how to attatch it
Help: 4l60e throwing PO740 code HELP!!
By matt evans in forum Automatic TransmissionReplies: 10Last Post: 11-02-2011, 05:52 PM -
WTB slip yoke 04 gto
By ledesma54 in forum Parts Wanted / TradeReplies: 0Last Post: 05-15-2009, 03:00 PM -
1st to 2nd Slip?
By 2000silverbullet in forum General HelpReplies: 3Last Post: 11-22-2007, 07:35 PM -
slip
By griftymcgrift in forum Automatic TransmissionReplies: 0Last Post: 11-07-2007, 12:35 PM -
Code P1870 & TCC Slip Table
By tblu92 in forum Computer & TuningReplies: 12Last Post: 05-22-2007, 05:18 PM
