Results 1 to 15 of 15
    okc
    Silver 2002 WS.6
    Red 1989 Formula
    Im considering..
    Alright im considering adding nitrous to my car. Just a small shot like maybe 75, but well i kinda have a small idea as to how it works or which are good or what will i have to do to get it going? Any help or suggestions?
    Laurel, Maryland
    2000 Grand Prix GTP
    2000 Trans Am WS6 M6
    Not finished with the install, but Nitrous Outlet has a lot of good stuff at the best prices.
    Here is my parts list of the major stuff I'm installing:
    Nitrous Outlet Single Nozzle Wet Kit w/ 10lb Bottle and 4AN Lines
    Nitrous Outlet Big Show Purge Kit w/ Dual Lines running to nostrils on the front
    Nitrous Outlet 4AN Nitrous Filter
    Nitrous Outlet Remote Bottle Opener
    Nitrous Outlet Automatic Bottle Heater
    Nitrous Outlet Spare Tire Mounting Plate
    Timing Tuner (Window Switch and Timing Retard upon Nitrous Activation)
    DynoTune Lean Shut Down Switch (shuts down Nitrous if the A/F mixture becomes too lean)
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged w/ a T67 Turbocharger
    2007 Chevrolet 3500 Dually Duramax: 3" Downpipe, Dual 4" Exhaust, EFILive Tuning
    Rice Killa JwMonE99's Avatar
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    More info on that timing tuner your using?
    okc
    Silver 2002 WS.6
    Red 1989 Formula
    About how much am im looking at here?
    Laurel, Maryland
    2000 Grand Prix GTP
    Quote Originally Posted by JwMonE99 View Post
    Basicly, it installs inline between the crank sensor and the ECU.
    The following can be programmed:
    - Window Switch (Nitrous)...adjust the window switch for when the Nitrous activates.
    - Base & WOT Spark...adjusts the spark for all around driving if you don't have a tune to run at peak performance...I will not be using this setting, sicne I will have my own tune through HP Tuners.
    -Retard (Nitrous)...automatically retards the timing a specified amount when the nitrous is activated.
    Outside:
    Inside:
    Here is how I have my wiring set up with a WOT Switch, Lean Shut Down Switch, and Timing Tuner...the difference is that my setup is backwards...it goes Timing Tuner -> Lean Shut Down -> WOT...I didn't want the Timing Tuner going off the Nitrous Retard when I shift and the WOT switch shuts off the Nitrous:
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    I meant a simple part number, I couldnt find any lol but thanks for all that info.
    I just bought a Zex window switch, wish I would of waited a little longer and got one of these.
    Junior Member Bottlefedz28's Avatar
    Nov 2009
    Lafayette LA
    RED ultra Z hood 125 shot
    02 Z28 3200 stalled
    i love the timing tuner my guy installed one when he did my system so the car does not drive around with 4 degrees pulled all the time
    Laurel, Maryland
    2000 Grand Prix GTP
    Sell te ZEX.
    http://www.nitrousoutlet.com/catalog...28&product=965
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    Quote Originally Posted by Bottlefedz28 View Post
    What is it like 2 degrees for every 50 shot right?
    How does it affect the motor performance wise or in general when you retard the timing while n/a?
    Laurel, Maryland
    2000 Grand Prix GTP
    Yeah, 1 degree for every 25hp of N2O.
    You're literally loosing hp...there is no reason to loose hp if you're only using the nitrous once in awhile. Best of both worlds is to run at peak performance and retard the timing on the juice.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    too much timing retard can cause a backfire as well. i've ran a 150 shot on stock timing. the 1/25 or 2/50 retard isn't need until you go above 150 or so.
    Laurel, Maryland
    2000 Grand Prix GTP
    Yeah, I'm going to have Frost "tune" it for nitrous, then go back to N/A timing and use my Timing Tuner to tkae back the timing found with the nitrous "tune".
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    Does anyone else sell one without the window switch?
    JUISSED Midnight02's Avatar
    Feb 2007
    Atlanta
    2002 Camaro SS
    I went with a NX MAF plate kit....it's a wet kit. I coupled the kit with a remote bottle opener (I wanted to hide it in the spare tire well), a bottle warmer, purge, Racetronix fuel pump and a FJO progressive mini-controller. I got the parts brand new from another board member dirt cheap and had Vengeance do the install and tune. At the end of the day it ended up being around $3K (I also added 3 Auto Meter cobalt gauges in a pod -- Fuel pressure, N2O pressure and a wideband O2 so that was a decent portion of that total). The cost of everything together was pretty expensive however it's a dummy-proof system....just what I was looking for. I can hit two buttons from the driver seat and all I have to do it hit the gas pedal -- the setup does all the rest.
    In short, it was without a doubt the best money I've spent on the car to date.
    2002 Camaro SS M6, 2.5 PRC 5.3L heads, TFS 228/230 cam, FAST 92, bolt ons + a 10 lb bottle in the back.
    1989 Corvette L98, A4, Full bolt ons, etc.
    Please don't provide direct links to non sponsors
