Thread: Buying 97 Z28
06-16-2014, 02:05 PM #1
- Jun 2014
- Ohio
Buying 97 Z28
I am wondering what HP I should exspect out this camaro I am buying. It has been bored 30over but not sure of what pistons and it has LT4 heads intake and hot cam. LT's with flowmaster exhaust bbk 58mm tb and it is a M6 car. Any ifo would be helpful. Thank
06-17-2014, 10:26 PM #2
Assuming it's tuned for that cam and other parts, and the heads aren't ported, maybe 330-340 at the rear wheels.
06-18-2014, 10:26 AM #3
- Jun 2014
- Ohio
Buying 97 Z28
heads are stock lt4. would porting them help anything without upgrading cam?
06-18-2014, 03:53 PM #4
Proper porting will almost always enhance an engine's airflow. This assumes it has the ability to pull more air in and expel more spent gases out the back while adding the correct amount of fuel.
06-18-2014, 06:30 PM #5
- Jun 2011
- Branchville, NJ
Spend 150.00 and put it on a dyno. Stop guessing.
06-18-2014, 11:10 PM #6
06-19-2014, 04:57 AM #7
Porting heads is a significant investment in time, labor and $$. With any modification that you wish to undertake, you seriously have to consider and balance those three items with the results that you will achieve. If the springs and such have already been upgraded then porting alone may be an option. However, if that is all stock and approaching 20 years old, your better investment may simply be a new set of heads once you do the math.
buying a zo6
By camarospade in forum CorvetteReplies: 12Last Post: 02-10-2011, 02:05 PM -
buying an Lq9 need help please
By AV8 in forum Internal EngineReplies: 2Last Post: 01-15-2010, 06:52 AM -
Buying Help
By littlevegas1 in forum Firebird / WS6Replies: 12Last Post: 03-19-2009, 12:17 PM -
Buying an '02 WS6
By bandit001 in forum Firebird / WS6Replies: 3Last Post: 06-23-2008, 07:57 AM -
Buying a Z28/SS need help
By killerinparadise1 in forum Camaro / SSReplies: 1Last Post: 11-22-2006, 07:21 AM
