Results 1 to 20 of 68
Thread: What oil are you using?
02-27-2014, 10:14 AM #1
- Apr 2011
- Johnstown,PA
Silver- 1999 Trans-Am, 2012 Sonic
I have been doing some reading on oils and there properties and was wondering what some of you here have been using and any suggestions on oils for a 100k + cars. I plan on some track days this summer and want the best protection and have seen Valvoline VR1 is highly recommended.
Here is one link I found interesting ZDDP values and High Zinc Oils • Speed Talk
Here's another: http://www.nonlintec.com/sprite/oils_and_zddp.pdf
This is the oil
Valvoline.com > Products > Motor Oil > Racing Motor Oil > VR1 Racing Oil (VR1)
If you could list your recommendations what you do with your car(street/track, street only limited miles, or daily driver) and mileage of your car and change intervals.
My mods listed below just bolt-ons with a Ls6 intake coming in springLast edited by kingls1; 02-27-2014 at 06:20 PM.
99 Trans Am, SLP Lid, Blackwing filter, smooth bellow, Ported TB, LS6 intake, Ws6 lower ram air box, OBX LT's, Magna Flow cat back, LS7 clutch, Tick MC, Hurst Shifter, Frost Tune, UMI SFC,LAC, STB, PB, Torq Arm, Super Hawk hood, Torq Thrust II, Kee Audio.
Strange S60 4:10's, D&S Rotors, S/S Brake Lines.
Nitto NT05R Track Tire's, 12.7 @ 108 / 1.82 60'
Wish list.
Coil overs, Heads & Cam
02-27-2014, 11:06 AM #2
I have used Pennzoil Platinum Plus Synthetic since I purchased the car new in a 10W-30 weight. I change the oil once a year, which ranges anywhere from 1,000 miles to 4,000 miles. Car currently has 24,XXX miles on it so not a good correlation to high mileage really, but that oil seems to be highly recommended and many people use it, inclusive of site members here.
02-27-2014, 01:13 PM #3
Penzoil Platinum as well, but in 5W-30.
02-27-2014, 01:59 PM #4
- Apr 2010
- Alabama
Amsoil Dominator Racing Oil 10w30. Every 3k is when I change it which usually comes out to once a year. My car is not a DD it is a fun street and track car.
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
02-27-2014, 05:01 PM #5
Mobil 1 Extended Performance 10w30
02-27-2014, 09:55 PM #6
I was using Mobil 1 until my most recent oil change where I "heard" that Comp Cams recommends against Mobil 1 for the LS1 (they changed their formula or some such). I heard it from a source that I trust. So after recommendation from members who have posted in this thread, I switched to Penzoil Platinum. It's my first use of it, so we'll see how it goes (had it in for about a month and change now).
My car is a daily driver approaching 90K miles. Engine still feels very "tight" and strong, despite daily WOT pulls through 1st and 2nd.
02-28-2014, 01:42 AM #7
Has anyone used or considered Driven?
02-28-2014, 06:19 AM #8
- Apr 2011
- Johnstown,PA
I've read good feedback on it but the Valvoline VR1 seems to be the biggest hit and is ranked 3rd on the list( ZDDP values and High Zinc Oils • Speed Talk ) the top 2 are short term racing oil only not intended for street use. The zinc content is what is the key, not to high or low but a happy medium. Also see that Joe Gibbs Driven has a oil just for LS based engines. Driven LS30 5W-30 Next Generation Synthetic
Back when I was building bikes Mobil 1 & Amsoil were at the top and I used them with great success but as always products continually change.
02-28-2014, 06:44 AM #9
- Apr 2010
- Alabama
Funny they don't even include any of Amsoil ' s racing oil on that list. If you look HERE it has higher Zinc ppm and their ZDDP ratings are the same when compared to the conventional VR1 racing oil. The conventional VR1 oil has higher Phosphate content though. Also Amsoil Dominator Racing Oil has higher phosphate rating in addition over the synthetic version of VR1. In my opinion conventional VR1 and Amsoil Dominator Racing Oil are fighting for the same spot as far as their ranking goes in top quality oils in both protection qualities and maintaining those qualities while under load. Yet for some reason the amsoil is still #5 only due to the psi rating, however being higher in Zinc, ZDDP, and Phosphate is much more important, to a point. Obviously, if the psi rating is really low it won't be a good oil to use because under load it won't work as well. However, once you get in the 90,000 and up range the psi rating doesn't matter as much and the actual ppm ratings are much more important. The only oil on that list that has all around higher values is Valvoline NSL racing oil (not street legal).
02-28-2014, 08:49 AM #10
02-28-2014, 12:13 PM #11
- Apr 2011
- Johnstown,PA
I do agree with the quality of Amsoil as my car is full of it other than motor and wouldn't be afraid to run it there also as stated above ran it in a built high H.P. Inline 4cylinder bike that was bored 205cc and it handled it with no issues. Just looking for ideas on what's used and what works. Keep it coming
02-28-2014, 01:12 PM #12
02-28-2014, 01:16 PM #13
- Apr 2010
- Alabama
Yep I am going to be switching all other fluids to Amsoil.
02-28-2014, 01:17 PM #14
Amsoil is always a safe bet. Unfortunately, it is hard to come by in our area unless I order it on line.
02-28-2014, 01:23 PM #15
A couple things to keep in mind with the VR1 racing oil.
One....it's not all synthetic. Not that it matters much, just means more frequent oil changes for some.
Two....the high zinc content that Valvoline claims in their VR1 from my understanding is that it's in the 20W-50 viscosity only. That's how it's sold on the shelf without the "off road use" warning because that viscosity doesn't comply with recommended viscosity from the car manufactures. The 10W-30 VR1 has less PPM's of Zinc to comply with todays cat converters as it's the recommended viscosity for newer cars.
I use the 20W-50 VR1 in a few cars here. An air cooled VW, and 3 different classic muscle cars. However in our LS powered vehicles I prefer to run Penzoil Platnum 10W-30.
I believe the recommended PPM's of Zinc for flat tappet engines is in the 1200 PPM range, and you'll hear that from quite a few of the cam manufactures. This doesn't apply so much to roller cam engines (such as the LS1) however there are other areas in the engine with high friction/high load that could use the extra lubricity that zinc provides such as piston walls and piston skirts. So although a roller cam engine "CAN" get away with less Zinc content, it's not a bad idea to have it anyway in my opinion.
Amsoil is good stuff, and since my classic cars generally only get the oil changed once a year I was thinking of trying their Synthetic high Zinc content muscle car oil.
However the difference in price between VR1 and Amsoil makes me just a bit hesitant. $6 a quart vs $9 a quart can turn away some people. I figure with once a year change intervals the difference isn't too bad. I'm just not so sure I'd be getting any better protection than the VR1 provides, with the only real difference being Amsoil is a synthetic.
- - - Updated - - -
Our local Napa's out here carry it for $9 a quart.Last edited by Firebirdjones; 02-28-2014 at 01:28 PM.
02-28-2014, 01:24 PM #16
FBJ - what's your take on the ZDDP additives?
02-28-2014, 01:31 PM #17
02-28-2014, 01:35 PM #18
I have no issue with them, the good stuff that is. I've never seen it sold on the shelf of the local stores, most of that I would consider snake oil, since technically they can't legally sell that over the counter since the EPA says it ruins cat converters.
The good stuff is what cam manufactures sell you when you buy a flat tappet cam. I should say it's what they recommend, and they likely won't warranty the camshaft unless a bottle is purchased from them.
Also GM sells it as well, called "EOS" or engine oil suppliment. I used to by that by the case and use a bottle in every brand new engine I started. Good stuff. Some people will run cheaper oil and just use a bottle of this at each oil change. However I think the price difference balances out to be the same in the end since the EOS is about $12 a bottle anyway, so you can just about spend extra on the Amsoil and not run the additive....
Lately I've been buying the break in oils from Joe Gibbs for fresh engines and not using the EOS, and from there use a high zinc concentration oil afterwards.
02-28-2014, 01:43 PM #19
Here's another little tidbit of info. Not that this means a whole hell of a lot but I find it interesting.
A couple years ago I bought a 502 crate engine from Scoggin/Dickey. This is a roller cam engine already. Among the thick booklet of paperwork they sent with the engine I read that they specifically recommended breaking this engine in with 20W-50 Valvoline VR1 racing oil. I think that says a little something about that oil...
02-28-2014, 01:46 PM #20
I've thought about that, but for me it seemed like a pain in the butt having to order it all the time and then waiting. I like the fact that I can run up to the store at any time. There is also a little mom and pop store called 7th Avenue that carries it as well as Napa.
