Thread: Electric Fuel Pressure Sender
10-02-2007, 02:21 PM #1
Where is a good place to install the electric sender that comes w/ this guage? The directions are vague and just say to install in "the fuel system".
10-02-2007, 05:15 PM #2
On the front of the fuel rail. Take the cap off & remove the valve stem guts, and it should have came with the fittings to fit. Be careful not to over tighten it, the end of the fuel rail will break if stressed...
10-02-2007, 05:30 PM #3
I thought that would be a place to put it, problem is, my nitrous system is a wet system and is already using that spot for the fuel sol. ... Do they make like a T or Y fitting to screw onto the end of the fuel rail so you can have both a spot for the fuel line, plus the sending unit?
10-02-2007, 05:38 PM #4
Yes you can get a brass T fitting. Mines the same way ! Good Luck !!
How Accurate are electric fuel pressure gauges? (Nitrous related)
By Blown Interceptor in forum Western MembersReplies: 11Last Post: 05-08-2007, 07:59 PM -
Anyone have an Electric Fuel Pressure Gauge for sale?
By Blown Interceptor in forum Western MembersReplies: 0Last Post: 03-01-2007, 08:31 PM -
FS: NIB Auto Meter electric fuel pressure gauge
By MagicMan in forum Parts For Sale / TradeReplies: 2Last Post: 10-12-2006, 08:55 AM -
auto meter fuel pressure gauge electric sender hook up
By SSJoe15 in forum General HelpReplies: 3Last Post: 01-07-2006, 03:23 PM
