Results 1 to 2 of 2
Thread: Shaking after coilover install
05-17-2017, 07:49 PM #1
As the title says, it's pretty straightforward. Installed some coilovers in the front end of my 06 today, and they ride smooth in a straight line, but while turning there's a rumble and some shaking. Could this be due to the little (maybe 12mm?) hex bolt that's above the 2 giant bolts that hold the strut to the hub? I didn't adjust it at all, got fed up after fighting a sheared off end link and dropped the car back down. Everything else is tight as it should be.
07-16-2017, 04:21 PM #2
- Jan 2009
- North Jersey
Just now seeing this thread. You didn't re-use the factory strut-to-knuckle nuts and bolts, did you? They are ONLY to be used ONCE. Before I replaced my front struts/bushings, I got the hardware specs from another forum and went to a Fastenal closest to my job. If you re-used the factory hardware, they could still be loose.
2002 Chevy Corvette C5 Z06 Coilover and Sway Bar Install - C
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 01-12-2011, 05:20 PM -
Ground Control Adjustable Coilover Kit
By RedVertTA in forum Suspension and HandlingReplies: 5Last Post: 06-18-2009, 10:20 AM -
Coilover shocks/Adjustable Suspension
By SVG210 in forum Suspension and HandlingReplies: 16Last Post: 02-05-2008, 09:27 AM -
QA1 Rear coilover kit (autofab)
By xssive in forum Parts For Sale / TradeReplies: 0Last Post: 03-15-2007, 06:10 PM -
New coilover set up
By driving in forum Suspension and HandlingReplies: 1Last Post: 11-07-2006, 02:14 PM
