Results 1 to 10 of 10
06-28-2009, 06:42 PM #1
- Oct 2006
- Santa Barbara County,Ca.
Onyx Black- '02 Camaro SS(replica) M6
Whistler Mod - long term durability?
Ok, I've been wanting to do this mod myself, but always wondered how durable (or not) it can be... For example; has anyone tried to "cheap-out" and use cheap paint, silicone, etc? I would imagine the headlight housing can get pretty warm on the inside? Any horror stories? Any input is appreciated, Thanks, Dave.
07-01-2009, 09:51 AM #2
- Jul 2006
- Greene, Iowa
Red- 99 Chevrolet Camaro Z-28
i did my whistler mod a good 3 years ago...still looks just as good as the day i did it. its all in the prep work you do. id imagine if you do a shitty job at sanding the chrome off for a good paint adhersion itll look like crap down the road. i just used a 1200 grit wet dry sand paper and sanded the chrome until i had the gray plastic showing everywhere i wanted to paint. used painters tape for the back mask and went to town with the good ole .97 cent can of krylon black gloss...and ued just a normal silicone clear caulk and ran a bead around the case and clamped togehter. not a leak or nothing
07-02-2009, 03:10 PM #3
- Oct 2006
Thanks for the input Steve!, I've had a spare set of new headlamp assemblies for quite a while now. I may as well give it a try. Just need to make some time and TAKE my TIME! I've done bodywork/prep. before, so I guess it can't be too different right? I'll start gathering supplies soon... any other input with personal long term experiences out there...? Thanks again ppl!
07-02-2009, 07:19 PM #4
- Jul 2006
- Greene, Iowa
i have no body/prep work...but am pretty good with a spray can. haha...i just took my time saning for the prep. i reccomend taking a heat gun or a damn good hair dryer to the outer seals though. heat up the silicon around the edge of the lense to make it come apart easier. that was probably the hardest part for me was getting them apart. then just peeled the rest of the silicone off when apart. sand and pay close attention to the ridges in there. youll know when you get to sanding. i put a good 3 thick coats on and let dry then put together
07-02-2009, 07:22 PM #5
- Nov 2006
- Broken Arrow, OK
Same situation as me. I acquired a second set to play with. I need new lenses for them, the originals were beyond repairable. Be extremely gentle after baking them to loosen the adhesive. They are very very brittle after baking. Scuff them up inside real well so the paint will adhere and they should turn out fine.
Also, paint the back housing black(or whatever color your desire). It makes them look so much better afterwards.
07-02-2009, 07:26 PM #6
- Jul 2006
- Greene, Iowa
hard to see them as the lenses were fogged when i took this pic (sand blast fog)
then probably one of the better shots after i did a plastic restore on the lenses
07-02-2009, 09:21 PM #7
- Oct 2006
Thnx for posting the pics... my lenses have the "sandblast fog" rite now too. I figure i'll eventuall polish those out too...
07-05-2009, 04:54 PM #8
- Oct 2008
- Coral Springs, Fl
Mine turned out ok. Painted them with regular rustoleum black, thhen went over with high temp clear coat. Looked better without the clear but holding up great. Would suggest to use high temp engine paint in about 2 to 3 coats. They should come out looking good and lasting longer than the headlight itself.
Heres what mine looks like
07-06-2009, 08:45 PM #9
- Oct 2006
Nice pics tatertot91, I think that my WORST fear is that the color (black) will fade over time and eventually turn into a grey color... I'd be so bummed if they faded in like two or three years... Maybe i'll use auto paint or UV safe paint, I've gotten a better grasp of this now (confidence), Thanks for the input fellas...
07-06-2009, 08:55 PM #10
Help: Short term and long term fuel trim readings can ANYONE help?
By DaytonaBlues in forum General HelpReplies: 7Last Post: 10-20-2013, 04:21 PM -
Ressurecting Trans Am from Long Term Storage
By Rhinohuey in forum General HelpReplies: 12Last Post: 12-01-2012, 10:28 PM -
rear o2's = long term fuel trim?
By M-Ten in forum General HelpReplies: 29Last Post: 01-27-2008, 02:45 PM -
Quick Long Term Fuel Trim Question
By Firebirdjones in forum Computer & TuningReplies: 12Last Post: 03-04-2007, 10:56 AM -
Long term storage question
By 02 HAWK in forum General HelpReplies: 1Last Post: 10-23-2005, 03:55 PM
