Results 1 to 2 of 2
03-10-2022, 02:27 PM #1
- Mar 2022
- SF Bay Area
Tick SNS torque max stage 2 ls2 DCR
Hello everyone I am putting together a lq9 with 243 heads so basically an iron block ls2. I have been looking at cams and really like the looks of the tick sns torquemax stage 2 v2 ls2 cam however playing with online calculators it looks like it will put me in the low 9s of dynamic compression. I emailed tick and they said it would be 9.2/1 on a stock ls2. IsnÂ’t that way too high for pump gas? Cam card says 44.5 IVC at .050, IÂ’m in CA and only have 91 octane any help as to if this cam will work will be greatly appreciated thank you!
Tick Performance "SNS" torqueMAX Stage 2 V2 Camshaft for LS2 Engines
Standard Lobes: 231/235 | .625"/.605" | LSA111+2
09-17-2023, 11:05 PM #2
- Aug 2023
- UK
red- 2009
Finding the right stock photos can sometimes be a bit tricky, but I can certainly help you out. When I needed Pittsburgh bridge stock photos for a similar project, I found that Shutterstock and Getty Images had a good selection. They offer a wide range of images, including various angles and lighting conditions, which can be handy for different projects. Just enter pittsburgh bridge in their search bars, and you should find a variety of options to choose from. Remember to check the licensing and pricing options to make sure they fit your project's budget and usage requirements.
Better cam: Tick Performance SNS Torque Max stage 2 or VRX4
By jb3golf in forum Internal EngineReplies: 4Last Post: 05-06-2014, 06:31 AM -
Tick-a-tick-a-tick-a-tick-a...Rear end when cornering
By bhunter0830 in forum Suspension and HandlingReplies: 8Last Post: 04-06-2012, 03:37 AM -
Monster stage 3 clutch and tick performance rebild
By Rk ws6 in forum Manual TransmissionReplies: 12Last Post: 05-30-2009, 11:26 PM -
HP III/Spec Stage II/Poly Torque Arm Bushing
By 30birdy in forum Parts For Sale / TradeReplies: 7Last Post: 08-17-2006, 08:29 PM -
Tick-tick noise: LS1 vs. Northstar
By Jack M in forum Internal EngineReplies: 1Last Post: 07-07-2006, 11:14 AM
