Thread: 2018 ss rear end
11-14-2018, 07:12 AM #1
- Jun 2012
- florida
2018 ss rear end
my 2018 ss rear end hit 10k miles and the rear end moans on turns when first driven. same with traction control off. any thoughts
11-14-2018, 09:17 AM #2
Moans? As in the gears or posi unit are making noise?
11-14-2018, 11:46 AM #3
- Jun 2012
- florida
how can i tell the difference
11-14-2018, 04:24 PM #4
If it is only making noise in turns, I would suspect a wheel bearing before a posi. If the noise is not constant, then not likely the gears. Another thing to check -- your rear brake calipers. It is not unknown for them to come loose and start making noise before all hell breaks loose.
11-16-2018, 06:01 AM #5
Isn't a 2018 under warranty?
Sent from my SM-G955U using TapatalkBoost gets you laid, unless your name is Jon.
11-16-2018, 07:41 AM #6
- Mar 2007
- Henryetta/Tulsa Oklahoma
Need to take it to the dealer, it needs a fluid swap at the very least. I believe there is a TSB out for rear diff issues. This has been happening since the 2016 release, pretty disappointing to see it still happening in newer models :/
Edit: GM Technical Service Bulletin 09-04-20-001E unless it has been superceded by a newer version, as at the time this was for 2016-2017 models, 2018 hadn't started rolling out yet.Last edited by Y2KArcticSS; 11-16-2018 at 08:21 AM.
11-16-2018, 11:29 AM #7
there is a TSB out about the cv axle bolts coming loose at the pumpkin. they have to replace with longer bolts and lock washers.
11-16-2018, 11:30 AM #8
TSB # 16-NA-399
Subject: Information on Replacing Half Shaft Fasteners with Revised Parts
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Cadillac
ATS-V
2016
2017
LF3, LF4, LT1, LT4
CTS-V
2015
2017
Chevrolet
Camaro
2016
2017
Involved Region or Country
North America and N.A. Export Regions
Condition
The technician may need to perform a repair that requires the half shaft bolts to be removed.
Information
This bulletin advises the Service Technician of new longer bolts and lock washers required to be installed during any repair that requires the half shaft bolts to be removed or replaced.
Three retainer assemblies required per half-shaft.
Each retainer (3) requires 2 bolts (1) and 2 washers (2) to make a retainer assembly.
Where applicable, each axle assembly uses 3 retainer assemblies per side.
Each repair kit contains 6 bolts and 6 washers. 1 kit for each half shaft.
Replacement of all axle bolts are required during repair.
Correction
If half-shaft has been separated from the differential:
Remove and discard only the half shaft bolts.
If required, clean and reuse retainers.
Replace the shorter bolts (1) with a new longer bolt (2) and washer.
Install the lock washers onto the bolts.
Install bolt and washer assembly into retainer.
Torque bolts to proper torque specifications. Refer to Fastener Specifications in SI.
Service stock half shafts may include POA bolt/retainer assemblies. These assemblies may require rework with longer fasteners.
The new half shaft bolts must be removed, measured and discarded if the length is incorrect.
Parts Information
Note: To obtain the bolts and washers, fax the form included in this bulletin to the GM Warranty Parts Center (WPC). Request WPC #816.
Use the Vehicle Identification Number (VIN), SI, and the GM Electronic Parts Catalog to determine the proper part numbers for the half shaft, if replacement is required:
Description
Part Number
Qty
Bolt/Washer
WPC #816
1 kit (6 bolts/6 washers)
IMPORTANT NOTE WHEN PRINTING THIS FORM: If the form prints out on two pages, make certain you fax BOTH pages so that the WPC receives all the needed information. Missing information will delay or prevent the part from being shipped.
Parts Request Form – Warranty Parts Center
Use this form ONLY for U.S. and Canadian Dealers. Export markets and Mexico Dealers must contact their regional Technical Assistance Center for assistance.
To: Warranty Parts Center
e-mail: warrantypartscenterUSA@gm.com
or WPC Fax: 248-371-0192
Attn: Temporary Service Parts
Part Being Requested: WPC #816 Bolt and Washer kit
Turkey Run 2018
By johnfin in forum Southern MembersReplies: 1Last Post: 06-23-2019, 02:34 PM -
2018 Jaguar XE 25T AWD
By pajeff02 in forum Domestics and ForeignsReplies: 16Last Post: 05-31-2018, 04:00 AM -
2018 parts
By johnfin in forum General Help - 6th GenReplies: 4Last Post: 05-16-2018, 02:38 PM -
gen 5 and 6 representing at 2018 gatornationals
By mrr23 in forum Almost Anything GoesReplies: 3Last Post: 03-21-2018, 05:43 AM -
Camaro GT4.R will be sold publicly in 2018
By Ed Blown Vert in forum General Help - 6th GenReplies: 2Last Post: 09-29-2017, 01:31 PM
