Results 1 to 3 of 3
08-18-2007, 01:04 PM #1
- Aug 2007
- Lansing, MI
Navy Blue Metallic- 2002 Chevrolet Camaro Z28
Change Carrier or Use "thick" gears
I'm getting mixed awnsers on doing my gear swap and just keeping my 2 series carrier (with 2.73 gears) and using thick gears (3.73) with the spacer. Some guys say I need to replace it with a 3 series carrier to do it right.
08-19-2007, 12:40 AM #2
I am making the same swap.I dont see the need to spend even more money to rebuild a 7.5" rear.buy a thick gear and be done with it.If you are going to swap carriers too then just spring for a real rear like a 9" or a 12 bolt.JMHO
08-19-2007, 07:25 PM #3
I went with the 3.73 gears for the 2 series carrier and it works fine. Only problem is these particular gears are whiny. Go for it.
Weather Channel Co-founder: "Climate Change" is "Not Valid"
By wileyCoyote in forum Political / Debate ForumReplies: 7Last Post: 10-24-2014, 06:44 AM -
What "Google" Thinks of "Climate Change Deniers"...
By wileyCoyote in forum Political / Debate ForumReplies: 5Last Post: 09-23-2014, 11:19 AM -
Senate Democrats to have "Climate Change" talk-a-thon...
By wileyCoyote in forum Political / Debate ForumReplies: 1Last Post: 03-10-2014, 08:40 AM -
Motive Gears "Checking Distance"
By jcws6 in forum DrivetrainReplies: 2Last Post: 07-02-2008, 07:11 PM -
How to recognize a "thick" ring?
By tici in forum DrivetrainReplies: 0Last Post: 12-06-2005, 01:22 AM
