    Northern Virginia
    BLACK
    Electrical problem with back-up lights
    Within the last week, the 20A TURN/BKUP LTS fuse has blown twice. The problem is somewhere in the back-up light circuit. With a new fuse, the turn signals work fine. As soon as I put it in reverse (M6), the fuse blows. Right now, I have a 40A fuse installed. It no longer blows the fuse, but the back-up lights don't work, and the battery gauge takes a nose dive when I put it in reverse, and the fuse gets rather hot.
    Where is the most likely place to look to troubleshoot this?
    Greene, Iowa
    99 Chevrolet Camaro Z-28
    i would take the taillights out, and inspect your wiring. maybe your reverse light on one side or the other is rubbing the tail light housing and grounding out on the body panel in there...and make sure the wiring is still somewhat loose, and doesnt feel like its getting caught on anything
    Northern Virginia
    BLACK
    Yeah, I kinda figured that would be the case. It sucks because I have an amp rack mounted where you need to get to the rear lights. Guess it's coming off
    Northern Virginia
    BLACK
    Update: I've determined that the problem is NOT in the immediate taillight area. If I disconnect the terminal that feeds the lights in the left rear corner of the vehicle, I can supply 12v power to the backup-light circuit on the taillight side, and the lights work fine. Update#2: I've now isolated the wire on the drivers side just ahead of the front seat, and it's ok from there back. So, the short is somewhere between, I guess, the backup switch on the tranny and where I last isolated the wire. Anybody know where the switch is that is activated when the tranny is put in reverse? I'm gonna find it eventually.
    We'll be back... GatorSS's Avatar
    THE SWAMP
    Light Pewter Metallic
    2000 Camaro SS M6
    Any update to this? I am havng the same problem. Every time I put the shifter to the reverse position, that fuse blows. Where is the switch that activates when shifter is put in reverse?
    Looks like it is on the passenger side of the trans case for an M6.
  1. electrical problem??SOS
    By okay469 in forum GTO
    Last Post: 07-29-2010, 07:51 PM
  2. Help: Electrical Problem
    By tiny47 in forum Stereo and Electronics
    Last Post: 04-19-2008, 12:14 PM
  3. Help: odd electrical problem
    By rapter34 in forum Stereo and Electronics
    Last Post: 04-06-2008, 06:59 PM
  4. Electrical/charging problem problem
    By jchcomputers in forum General Help
    Last Post: 02-23-2007, 06:59 AM
  5. Possible electrical problem?
    By GottaHaveLS1 in forum General Help
    Last Post: 02-10-2006, 01:58 PM
