Results 1 to 20 of 44
08-15-2009, 11:39 AM #1
- Jul 2009
- AL
First Ever: 100% stock LS1 Dyno (hahah!)
I am actually kidding but still kinda wondering if I have one of the few dyno graphs for a truly stock LS1 ever as of this morning
The 2001 SS still has a paper air cleaner element even, totally, totally stock car.
I wanted a baseline then in goes PCMFORLESS tuning with a 160 thermostat (mostly just to eliminate skip-shift cleanly), an SLP "lid" (low restriction air cleaner box with a K&N element in it) and a catch can to trap those pesky notorious ping-causing LS1 oil vapors.
I was frankly, surprised.
Even at 305RWHP, with a manual tranny, that should be 358HP at the engine. That is up almost 25HP over the rating of 335HP (315 for 2001 LS1 with LS6 intake, add SLP cold-air and center mount exhaust worth 10 each).
Heat really affected the car's repeatability (the runs were consecutive).
The 3rd pull shows some evidence of timing retard, I think. Heat and oil vapors would aggravate that for sure if that is what I'm seeing... anybody on here with a lot of dyno experience have thoughts on it?
-T
08-15-2009, 12:54 PM #2
- Feb 2007
- San Diego, CA
To preface: I want to state that I'm not saying anything against you as I find your dyno results to be exactly what they should be. Instead this is aimed at folks that think the drivetrain in an SS is any better than that in a Z28.
This dyno chart is why I wish folks would stop saying "It's an SS so it has to be better/faster/quicker (you pick)". I have a Z28. The 1st time I dynoed it as a stocker it put down 306rwhp/323rwt. The car has an A4 tranny. This was back in April 05 and the car had 29,xxx on it. I don't have the graph as it was lost when my old computer crashed in 07.
While the suspensions (wheels/tires and shocks) are different and the SS has the fresh air hood, the drivetrains are identical. SLP, OTOH, offered some items that afforded a performance gain (lid + headers are indeed better than stock and cast iron exhaust manifold).
I hope you have as much fun modding your car as I've had modding mine. And take it to the track to see what it'll really do. After all, you can't race on a dyno....
08-15-2009, 03:17 PM #3
wow 316 is great. thats 370ish motor. 01's were rated at 325, but probably should have been more like 350.
08-16-2009, 04:56 PM #4
- Jul 2009
- AL
The dyno was exactly where it should have been which is what I was pleased with.
You are 100% right about Z28 vs SS... the ONLY option the SS has that would make ANY gains on the dyno (with the hood open and the car sittings still) is the SLP Center Mount Exhaust (10HP).
Take stock 305RWHP for Z28 model with stock exhaust... add 10 for CME... and voila!... 315 (which is just about what my car did).
The SS is a nice looking car, has "collectibility" (?) going for it but not much... they built way too many of them.
(my '93 Cobra Mustang in the garage is a rare car... it is a garage queen for that reason and I am driving the SS daily)
Things I'd do to a Z28 would be a bit louder exhaust and cold air kit (lid).
The SS already has the "functional" scoop which may help a bit for cold air, but just looks nice.
The only real leg-up for the SS vs a Z28 is just as you say the suspension... the Bilstein is pretty neat.
I gotta say though had I found a better deal (good car at good price) on a Z28 I would have foregone the extra cost of the SS.
But I couldn't find anything but modded out, used up junk in the area.
The SS was worth the extra trouble to me.
I will say the SS hooks a lot harder than my '93 Z28 though... 1inch wider tires and the Auburn differential help with that... the large but factory drivable clutch helps too (can do "street tire launches" again which I could not with the Spec Stage III in the '93 model I had).
All said, I am very happy with the SS.
But if just going fast in a straight line is the ONLY thing on your mind, a Z28 is virtually identical in most regards, or with the cost delta in mods... is totally equal.
I just figured if I take a Z and upgrade it the same as the SS, it is a modded Z28 for the same money as buying the SS already "modded" and without the stygma of worrying if the mods were half-donkeyed or done "right".
BTW, I drove my '93 Z28 (preblower) with FIPK, cat-back and blaster coil (110k miles) to a 13.14@104.41 at Beach Bend (Bowling Green, KY) Nov 10, 2001 and have the video of it.
That run was stock clutch and Eagls GS-Cs.
It was a college day reunion for some of us and though I lost to a modded '98 Cobra on drag radials by .04s... I cleaned house vs 5 other competitors for reaction time average and best of day
I probably won't be tracking the new SS for a while.
I just got it and want to just enjoy it for a while.
But if I do get a chance, I might push it down the 1/4 just to shake the dust of middle age outta my hair a bit
I'll report back if I do with the times.
-TLast edited by Teeeman; 08-16-2009 at 05:38 PM.
08-16-2009, 05:44 PM #5
- Jul 2009
- AL
Stuff I've read ... I thought the '01/'02 Z28s were 315HP (with the LS6 intake and think they all got 11.75" clutches for manual cars).
The SLP add-ons for the SS were 10 for CME and 10 for cold-air hood.
So the car should be "rated" 335, but SLP told me 345... which matches your number... so I'm still confused a bit (laughing!).
Are you 100% sure that the '01/'02 cars were rated 325? IF that is the case then I finally understand SLP quoting 345HP for the SS.
I do have a lid on order and a tune. Should be worth 10-15 HP once installed (160 thermostat).
Also have a catch can in the mail... the cooler t-stat and tune and catch-can might help the car be less subject to losses for consecutive "pulls" or consecutive runs.
-Terry
08-16-2009, 06:05 PM #6
08-17-2009, 05:55 AM #7
- Jul 2009
- AL
"an LS1 is an LS1"
Yes!
That is my conclusion too at this point
-T
08-17-2009, 07:54 AM #8
08-17-2009, 11:35 AM #9
The 98-00 actually had a slightly bigger cam than the 01-02 cars. I believe the exhaust manifolds were the same, where did you read that? In the end all A4 ls1 cars will dyno 280-300 hp, and all m6 cars will usually read right around 300-320. ls1 is an ls1 is an ls1 ls1 is an ls1 is an ls1 ls1 is an ls1 is an ls1 ls1 is an ls1 is an ls1 ls1 is an ls1 is an ls1 ls1 is an ls1 is an ls1ls1 is an ls1 is an ls1ls1 is an ls1 is an ls1ls1 is an ls1 is an ls1ls1 is an ls1 is an ls1ls1 is an ls1 is an ls1ls1 is an ls1 is an ls1ls1 is an ls1 is an ls1ls1 is an ls1 is an ls1ls1 is an ls1 is an ls1ls1 is an ls1 is an ls1ls1 is an ls1 is an ls1ls1 is an ls1 is an ls1ls1 is an ls1 is an ls1ls1 is an ls1 is an ls1ls1 is an ls1 is an ls1ls1 is an ls1 is an ls1ls1 is an ls1 is an ls1ls1 is an ls1 is an ls1ls1 is an ls1 is an ls1ls1 is an ls1 is an ls1
hehe
08-17-2009, 12:52 PM #10
- Jan 2006
- Shepherd, Michigan
bigger is not always better... especially with restrictive exhaust manifolds. however..i am sure that the cam change was for several reasons..1 emissions..then 2 the standard bumpstick was changed out due to GM policies regarding universality of parts
1998 - 2000 Fbody
202/210 int/exh @ 0.05" duration
0.496" / 0.496" int/exh lift
116 LSA
2001 - 2002 Fbody
197/207 int/exh @ 0.05" duration
0.467" / 0.479" int/exh lift
116 LSA
in 2000 they redesigned the manifolds for new emission standards
here
here
08-17-2009, 03:28 PM #11
08-18-2009, 04:27 AM #12
08-18-2009, 05:15 AM #13
- Jul 2009
- AL
Great info, thanks for providing!
-Terry
08-18-2009, 06:39 AM #14
08-18-2009, 06:53 AM #15
08-18-2009, 09:07 AM #16
08-18-2009, 09:13 AM #17
08-18-2009, 12:10 PM #18
- Jan 2007
- Knoxville, TN
B2300 (Fluffy) Retired- Plain-Jane Dodge Truck
I would suggest the differences in dyno numbers is due, by far, to differences in the dyno itself, correction factor, calibration of weather instruments, and running condition of the car (including how warm/cold the engine & intake are) rather than in "factory freaks" or slopply factory tolerances. In fact, I'd be willing to wager that all LS1s of a like year (ie....98-00 and 01/02) that have the same intake and exhaust would dyno within 3% of each other if all the above conditions were equal.
In short - I don't believe in "factory freaks".
08-18-2009, 06:30 PM #19
- Feb 2006
- GARDEN GROVE, CA
BLACK- 2002, CAMARO Z28
Mine 100% stock was 310 and 329. Slightly above average but not a freak.
08-18-2009, 07:12 PM #20
Mine is completely stock as of now. Anyone wanna shoot some performace parts at me I won't complain... lol
What do stock LS2's dyno?
By Mike0202 in forum GTOReplies: 4Last Post: 04-06-2010, 02:08 PM -
Just got off the Dyno (stock T/A)
By 00BadBrd in forum Dyno InformationReplies: 20Last Post: 10-12-2007, 03:17 PM -
300 Mexicans!!! hahah
By 96z28 in forum Almost Anything GoesReplies: 7Last Post: 08-31-2007, 12:57 PM -
By 00BadBrd in forum Dyno InformationReplies: 1Last Post: 08-13-2007, 07:25 PM -
Hahah K-fed
By KyleLs1 in forum Almost Anything GoesReplies: 17Last Post: 08-22-2006, 08:17 PM
