Results 1 to 20 of 21
Thread: What should I get next?
07-15-2010, 03:20 PM #1
So I might be selling my 96 Camaro and I want to use the money from that to put towards the SS.
Current mods are in signature. I definitely want to get a DS safety loop, but does anyone else have any other recommendations?
Front and rear sway bars was my thinking?
I hopefully will have about $750 total to spend. It doesn't necessary have to be suspension mods, but couldn't think of anything else really so I'm open to any ideas.
JonBoost gets you laid, unless your name is Jon.
07-15-2010, 03:37 PM #2
Maybe put the money into an intake and TB? You've done quite a bit of drive line work. My guess is your ready for some more powa..?..
07-15-2010, 03:40 PM #3
Oh I am definitely ready for more power trust me
I still haven't decided on Procharger or H/C/I. If I go with Procharger, I'll probably run 8psi on the stock motor. I know the FAST intakes don't like FI.
07-15-2010, 03:46 PM #4
07-15-2010, 05:29 PM #5
I dont know if u like the bottle but maybe a 150 shot...
07-15-2010, 06:36 PM #6
- Nov 2006
- Broken Arrow, OK
Unless I missed it somehow, I didn't see any mention of a torque arm. Thats where I would go instead of sway bars.
07-15-2010, 06:37 PM #7
Nice catch Y2K. Didnt even think of that.
07-15-2010, 07:55 PM #8
front suspension= upper lower arms, k member?
07-15-2010, 08:20 PM #9
I have a TA (BMR Trak Pak) already, however since lowered the cross-member for the TA now hits on speed bumps. Will the front upper and lower A-arms help more than sways? Car is basically being built to be a street warrior, but will see some track time. Other thought was maybe a set of MT on some used rims for track use since I can't really make use of the 9" with the Nitto's.
07-15-2010, 08:30 PM #10
- Nov 2006
- Broken Arrow, OK
Add the TA to your sig then
I would do the sways ahead of A-arms, unless your A-arms are in need of replacing. The advantages of A-arms are being adjustable for auto-x and some weight savings, but a lot of the aftermarket A-arms are not as durable as the factory ones.
Some MTs would be a really good idea IMO. Those Nittos are not giving you the best traction, especially since you have a real rearend that can handle the abuse.
07-15-2010, 09:06 PM #11
I can probably cut about .5 secs off my 1/4 mile with MT's. Current best 60' is 1.906 with the Nitto's. Only downfall is I will only enjoy them like 6-12 times a year
07-15-2010, 11:30 PM #12
07-16-2010, 12:11 AM #13
Sheezus crimeny make it faster already
sway bars are a definite sotp improvement in the corners.
A watts link would be nice if you care to corner carve
I thought I read you couldn't use a driveshaft safety loop on lowered cars?
07-16-2010, 01:20 AM #14
- Nov 2009
- Jacksonville FL
TRIPLE BLACK- 2000 CAMARO SS M6 #2100
I say bolt on some ol' N2O on that bad boy! $750 is about the right amount for it. On the flip side you will need a tune as well so theres another $600 give or take.
07-16-2010, 09:21 AM #15
I am not sure if that's true or not on lowered cars. I do have the upgraded yoke and DS already...but I still like to be as safe as possible. I think the only one I saw that worked well with my current set-up was the Lakewood unit. I don't think the UMI or BMR one works b/c of my TA and DS size. Clearance is an issue.
NOS....hmmm. Not a huge fan, but...not totally against it.
07-16-2010, 10:00 AM #16
07-16-2010, 10:05 AM #17
- Nov 2009
- Jacksonville FL
I have the Lakewood one... I wasn’t a fan of nitrous either until I found out that most if not all of the horror stories are from people not getting the proper tune with it. As long as you get the right tune with it then it’s just as safe as anything else. It’s definitely the best bang for your buck out there!
07-16-2010, 05:57 PM #18
07-16-2010, 06:00 PM #19
Without even reading the above replies as to what you should get:
Your ass out to Pennsylvania in two weeks for the party.
07-16-2010, 06:18 PM #20
- Oct 2008
- Coral Springs, Fl
I'd say your due for H/C/I
