Thread: Ported Stock MAF
04-22-2010, 10:01 PM #1
- Jul 2009
- Mississippi
white- 1998 Trans Am a4
Ported Stock MAF
I just installed a slp air lid and ported the maf and when i floored the car the service engine light came on. What are these codes and will they hurt my car if i drive it and performance wise?
It threw these codes:
po1404
po151
po131
po157
04-22-2010, 10:28 PM #2
- Nov 2006
- Broken Arrow, OK
http://obdii.com/codes.asp
You can use the link above to check your trouble codes. Porting the stock MAF was a bad idea.
04-23-2010, 10:43 AM #3
- Jul 2009
- Mississippi
Why is it a bad idea?
04-23-2010, 10:45 AM #4
because the stock MAF works fine, once u start going with aftermarket MAF's and porting the stock you need to re-tune the car and it can cause all kinds of trouble.
04-23-2010, 11:09 AM #5
Stocker is good as-is for applications up to 500 or so HP.
04-23-2010, 11:13 AM #6
- Jul 2009
- Mississippi
Thanks and is it ok if i just de-screen one?
04-23-2010, 11:33 AM #7
- Apr 2008
- Madison, WI
no. leave the stock MAF alone
04-25-2010, 01:53 PM #8
Any modification to the MAF throws off the fueling. All sorts of people will tell you that they have done this and that to their MAF and their car runs fine. Quoting Greg Banish, a noted GM tuner, modifying the MAF can alter your fueling by as much as 13% if I recall correctly. Essentially, the PCM is interpreting the data from the MAF based upon a known flow calibration. When you alter the flow by de-blading, de-screening or porting the MAF you throw off the calibration.
04-25-2010, 02:18 PM #9
- Jan 2010
- texas
silver- 2000 formula
is it running richer or leaner?? seems my car has always run rich....even after the maf mod......kn filter..and LT's......when the money train rolls in.....getting a tune
04-25-2010, 07:22 PM #10
- Nov 2006
- Broken Arrow, OK
Porting the MAF leans it out. Adding long tubes makes it richer.
04-25-2010, 08:04 PM #11
I have a stock MAF on one, and the other has ported ends that bolt to the stock housing.
The stock MAF was easy to tune. The other car took a bit of tuning in the MAF tables to get it decent.
If you really really wanted to play with the MAF, rather than removing screens, and grinding on the housing and possibly ruining it,,,,,I'd personally just bolt on the ported ends that come without the screens.
If you don't like it or you have problems, it's easy to switch it back to stock ends. Either way, tuning is needed.
I thought the ported ends were still available?? Maybe not.
04-30-2010, 01:04 PM #12
Like it has been said. Leave the stock one alone unless you know exactly what you are doing and why.
09 Vulcan 900 custom.
2007 Subaru Legacy 2.5i
1998 Z/28 Hardtop A4 | Y2K wheels | SLP Lid | Magnaflow catback |cutout | Hotchkis LCA'S/PHB | BMR TA and D/S Loop| Tuned by Frost....300rwhp/308rwtq
97 Cobra- bolt ons | full exhaust| 4.30's| suspension | SCT tune- sold!
Question: ported stock tb
By bpopham22 in forum External EngineReplies: 1Last Post: 12-19-2010, 03:22 PM -
ported LS1 heads Vs. stock LS6
By krazykarl454 in forum Internal EngineReplies: 6Last Post: 12-02-2009, 08:00 PM -
Question: 243 Stock VS Ported 5.3
By HitManLs1 in forum Internal EngineReplies: 6Last Post: 07-02-2009, 12:25 AM -
ported stock T/B and 10 bolt
By purdueranger in forum Parts For Sale / TradeReplies: 1Last Post: 09-25-2006, 06:53 AM -
For Trade Stock 1998 Ported and Descreened MAF Looking for STOCK ONE!
By EvilCamaroSS in forum Parts For Sale / TradeReplies: 5Last Post: 01-27-2006, 12:12 PM
