Thread: pcv swap
12-09-2010, 05:04 AM #1
- Oct 2009
- The Woodlands/spring/houston
pewter- 99 trans am
pcv swap
Can i run any pcv on my car? im lookin to replace it as i have a split in the hose and i hear that can be a bit pricey for what it is.
12-09-2010, 06:46 PM #2
- Jan 2010
- texas
silver- 2000 formula
dude.....dont waste any more time or money on that crappy pcv system.......get the LS6 valley cover
12-09-2010, 06:46 PM #3
- Jan 2010
- texas
12-10-2010, 05:54 AM #4
12-10-2010, 12:47 PM #5
- Jan 2010
- texas
duct tape? a new pcv hose assembly will set you back more than the cover
12-10-2010, 12:50 PM #6
12-13-2010, 12:35 PM #7
PCV is a couple of bucks at any part store.
Here is the thread on how to make a fix. I've done it and it works.
http://www.ls1.com/forums/showthread...ght=pcv+repair
You also need to follow the hose towards the back of the intake and check the it where it comes together with another hose that goes to the back of the valve cover. At this junction it also has a tendency to break. The whole pcv hose assemble cost around $70 bucks on gmpartsdirect. How ever the LS6 Valley tray cover is around the exact same amount. It takes a little more work but is worth it.
If you are in a real tight jam for money and need a quick fix for about $12 you can get some vacuum hose connectors and make a fix. Need a T section and a L section so that you can make it a split and have it facing the right angles. I have a pic if you need a clearer idea. PM me if needed.
12-30-2010, 05:45 AM #8
- Jan 2010
- California-Sacramento-Roseville
Red- 2000 Chevy Camaro Z28
Use epoxy for now,,,to cure any pcv connector or hose issues. I did and it works great.
As long as your surface areas are cleaned with alcohol this will work.
Trans swap for swap
By [CJ] in forum DrivetrainReplies: 0Last Post: 08-12-2011, 12:11 PM -
Engine swap and computer swap
By mrmiatanut in forum Computer & TuningReplies: 4Last Post: 09-08-2007, 05:10 PM -
To Swap, or not to swap, that is the question.
By HasselZ28 in forum Camaro / SSReplies: 6Last Post: 08-11-2007, 07:58 AM -
Got a 94 Stang, want to swap a ls1 into it. Anyone hear of a swap kit?
By oxemoron in forum General HelpReplies: 6Last Post: 01-30-2006, 01:02 PM
