Results 1 to 3 of 3
    Jan 2015
    Shenandoah Junction, WV
    2001 Trans Am WS6
    need new ignition assembly plus keys
    My longtime housemate demolished the only set of keys to my 2001 Trans Am WS6 by driving over them with a riding lawn tractor.
    We found the mangled and notched trunk key, the fob in pieces, and the straightened key ring, but no ignition key...so no coding to make a new key, which makes locksmith key replacement roughly a $500 job!
    Classic driver rather than mechanic here...but it is my understanding that the computer handshake is only between the key and the ignition.
    Thus, if I can find a replacement ignition assembly that comes with its own set of keys, from a junkyard or a parts dealer, I hope we can just replace the ignition assembly and bypass the entire problem.
    If you have any insights or suggestions on where to find an ignition assembly with its own set of keys, please let me know!
    Many thanks!
    It is actually between the key, the ignition lock and the car bcm.
    You have 3 options.
    1 - dealership, take your registration and they can order the correct key.
    2- vat bypass mod. it's not difficult but there are IIRC 13 possible chips to choose from.
    3 have a tuner or tuning software turn off vats.
    Sep 2010
    Bel Air, Maryland
    '02 Trans Am WS-6, 6M
    You have 3 options.
    Some locksmiths should be able to help too, there is a device that can determine the resistor chip that is needed for the VATS, and the locksmith can even rebuild and recode the tumblers if needed.
  1. Engine Assembly Tips Part 2 - 16 More Engine Assembly Dos An
    Last Post: 10-11-2013, 05:00 PM
  2. Help: Locked my keys in
    By blackbird0230 in forum General Help
    Last Post: 06-16-2010, 11:45 AM
  3. Lost my Keys!! D'oh!
    By Twizz in forum General Help
    Last Post: 06-08-2009, 02:37 PM
  4. Why NOT to leave your keys in the ignition
    By eddielb in forum Western Members
    Last Post: 04-12-2007, 07:16 AM
  5. My Keys Were Stolen! What To Do?
    By badata in forum General Help
    Last Post: 04-07-2007, 03:35 PM
