Results 5,021 to 5,040 of 7109
05-02-2016, 06:35 AM #5021
Just got my new PS pump bracket. Nice piece for $50. My OEM one has a striped threads for the pump bolts.
Also the OEM part is no longer produced, you either have to find one from a junkyard, install as helicoil or order one like this.
I could have helicoil but this looks so much better then the OEM piece so why not.
05-03-2016, 02:14 AM #5022
Or, just bend the boot on the MSD wire. I did that on several of ours to gain additional clearance.
05-03-2016, 02:35 AM #5023
05-03-2016, 07:45 AM #5024
I needed to go with the truck wires because the 5.3/6.0 coil packs sit higher on the valve cover then the LS1 coils.
05-03-2016, 08:13 AM #5025
05-03-2016, 06:36 PM #5026
So I go about tonight trying to find an annoying damn noise that's been going on for a while. I narrowed it down to the ps pump. I figured that the bracket that the pump bolts to might be the issue. 2 of the bolt holes had been partially stripped, how no clue. But I didn't expect to find this...
Sure glad I got this...
05-03-2016, 08:26 PM #5027
05-03-2016, 09:28 PM #5028
- Aug 2007
- Greensboro, NC
Pewter- 2002 Trans Am WS6 M6
The set I bought is from 6litreater design. If your just wanting one seat done your probably better off hitting up a local shop. Most every place on online sales kits. I did see one or two that sold single seats but it was vinyl. The set I got is for both front and rear seats and ran me about 1250 after discounts. That's with some custom work. They start at 1100 for a full set.
05-04-2016, 02:24 AM #5029
05-04-2016, 03:53 PM #5030
- Apr 2010
- Alabama
Not for my TA but for my Vette...
Although it came with a broken tab on the bottom.
Sent from my HTC6535LVW using Tapatalk1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
05-05-2016, 03:07 AM #5031
With the broke off tab it'll weigh less and hence your car will go faster. Just sayin'.
05-05-2016, 03:09 AM #5032
- Apr 2010
- Alabama
Lol well IDK if they'll fix it because my wife didn't notice the damage when it came and I wasn't home. But I think it will be pretty easy to get fixed. At a minimum I'll cut the tab off my stock bumper for now and attach it.
05-07-2016, 02:07 PM #5033
- Apr 2010
- Alabama
I hate installing crank pullies....
05-09-2016, 07:39 AM #5034
Took my '99 ws6 with fixed tranny mount, new pads, rotated tires and all fresh filters & fluids (diff, tranny, engine oil, coolant) maybe for first time ever on all but oil...
... for a really solid high-rpm back-roads drive and beginning process of bedding in the new brake pads a la TireRack and other sites. Got to put a few hundred miles on them before I really do the bedding heat-up/cool-down process, right ? Any common mistakes with pad-bedding on used stock rotors and new stock GM pads (semi-metallic) I should know about?
She's coming to life after a long slumber. (Only used 50 miles/yr. from 2002 to 2012 by 1st owner, per 2nd owner I bought from).
05-09-2016, 06:35 PM #5035Ported/Polished throttle body, Lingenfelter launch module, SLP line lock, QTP exhaust cutout, LS7 clutch, K&N, Ceramic coated longtubes, no cats, 3" exhaust, Flowmaster "B", Eibach springs, Midwest Chassis 9" rearend w/4.10's
05-10-2016, 03:19 AM #5036
I drilled holes in the underside of my hood for some heat extractors, to match the nostrils of the ram air hood. Didn't think it would be such a PITA, but it took nearly 5 hours start to finish!! I then made some minor adjustments to the exhaust to stop a rattle. Then changed the oil and put in some fresh oil. Only had about 1500 miles since the last time I changed it May 2015. LOL
1998 Pontiac TA, stock heads, FAST 90, FAST 90 TB, FLP LT, off road y-pipe with cat delete, flow master muffler, comp cams 54-457-11 223/231-610/617-112 LSA, Pro charger D1SC with FMIC @ 8psi, FROST tune, VIG 3200 stall, built 4l60e, snow meth kit, MOSER 12 bolt 373 gears, Derale 13900 trans cooler.
05-10-2016, 03:29 AM #5037
Not a TA, but its an F-body. I helped my buddy Brian out with a Tick clutch master cylinder on his 2001 Camaro SS. Pretty straight forward install. Only issue was the wires under the brake power booster make it a close and tight fit. Then when we were on the home stretch and it was time to bleed the system, I dropped my F-IN SOCKET INSIDE THE BELL HOUSING OF THE TRANSMISSION!!!!! Holy mother of GOD what a pain to get that out. We kinda got lucky and separated the case and used 2 magnets to fish it out. The only other possibility would be to remove the entire assembly out of the car.
05-10-2016, 03:42 AM #5038
05-10-2016, 06:31 AM #5039
+1 with pajeff. Bed'em right away. I use the 30 30 30 method described in TireRack.com . Always had good results.
'02 Black RamAir M6--Kooks LTH, Magnaflo, Lowered Eibach springs and Bilstien shocks, Tuned By Frost, K&N & SLP box, Smooth bellows, polished TB, Spohn perf. suspension, shock tower brace. UMI 3point SFC. Front & side splitters w/ canards. American Racing 18" wheels & Mich. Pilot SS titres
'76 LagunaS3 - 355ci , 350 turbo, 3:55's
05-10-2016, 07:36 AM #5040
Thks Gents !
new guy just got my first trans am today
By roger_johnson2002 in forum New Member IntroductionsReplies: 9Last Post: 07-14-2011, 08:35 AM -
Found this on the windshield of my Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 60Last Post: 03-10-2009, 12:11 PM -
Got into an accident in the Trans Am today
By ls1camino in forum Almost Anything GoesReplies: 30Last Post: 09-21-2008, 04:32 PM -
Just got my Trans Am today!
By vannatte in forum Firebird / WS6Replies: 34Last Post: 09-20-2007, 09:57 AM -
First time at Track today!!! 2000 Trans Am ws6
By gimmeadonut in forum Drag RacingReplies: 1Last Post: 11-12-2005, 01:34 PM
