Results 201 to 220 of 220
05-07-2012, 06:32 PM #201
- Apr 2008
- Madison, WI
And yes I was out there with a tape measure....and the neighbor heard me cussing and asked "Whats a 5.0this?"...J/K
05-07-2012, 06:32 PM #202
05-07-2012, 06:33 PM #203
05-07-2012, 08:01 PM #204
05-07-2012, 09:04 PM #205
03-20-2013, 05:46 PM #206
- Apr 2008
- Madison, WI
I started playing around the DFCO (Decel Fuel Cut Off) settings to make it come on a little more often and see if it'll give me a MPG boost. I'm also thinking about running open loop and leaning out the cruise areas for better mileage. It seems to correct back to stoich when I make changes and run closed loop.
-------------------------------------Kooks 1 7/8" race headers, Kooks ORY, Borla catback, Nitto 555R, LS6 intake manifold, Shaner S3 ported stock throttle body, SLP lid, smooth bellows, JAAM Ram Air kit, Elite Engineering catch can, LS6 valley cover, EGR and AIR deleted, Frost tune, and Simpson Racing child car seat in the back. 13.2 @ 108MPH
03-20-2013, 06:32 PM #207
Those two things give me the biggest mpg gains. DFCO wasn't even working on my wifes car, the rpm activation rpm was never reached during normal cruise.
I keep it in open loop and command the AFR I want in the light throttle cruise areas. Had my wife car this way for a couple years now.
03-20-2013, 06:41 PM #208
- Apr 2008
- Madison, WI
yah, the stock DFCO settings were nearly worthless on my truck too. I lowered the rpm (so it'll come on when I'm above that), raised the MAP sensor enable (so it'll come on sooner), and messed around with the spark enable and mulitpliers (again so it'll get into DFCO sooner). I can feel it working now. I let off the throttle at 70mph...it coasts for a second or so...then the fuel shuts off and it feels like its engine braking. I'm gonna play with it some more.
03-21-2013, 03:45 AM #209
03-21-2013, 08:30 AM #210
03-21-2013, 08:33 AM #211
That sounds like the off RPM's probably need some tweaking so it stays on longer. I set mine as low as I can go without stalling when coming to a complete stop. I think I have my "off" rpm at 1100.
If you get too low the engine will struggle to maintain idle or die because the fuel is still cutoff, especially if you have a cam in it. Just have to play with it till you find what works for yours.
03-21-2013, 08:56 AM #212
- Jun 2007
- Baltimore, MD.
Bright Red- 2000 Pontiac Trans Am WS6
Yessir, mine was a bit high....1600 entry/1000 exit, so I lowered it to 1000/800 to try out.
09-30-2020, 10:49 PM #213
- Sep 2020
- Whiteville tn
Pm me same info please
Yesterday, 02:02 PM #214
- Sep 2024
- Maryland
Blue- 2002 Silverado LS 4wd
I just installed new heads, cam, LT headers, TBSS intake on my ?02 Silverado LS. Has factory 3.73 gears. I bought an HP tuner with 2 credits, now have to pay for a training class to unlock ?read only? columns to get deep into tuning. Once I get the AEM wide and installed I will take the class and let you know how it goes. Just be aware buying the tuner and credits only gets you base level access to start tuning with.
Yesterday, 03:59 PM #215
- Jun 2007
- Baltimore, MD.
This thread is older than me, but you do not need to take any classes to be able to unlock anything or be allowed to tune your truck or car. If the vehicle calls for 2 credits, then using those 2 credits will get you a new "application key" and let you "tune" an unlimited amount of times.
Today, 03:01 AM #216
- Sep 2024
- Maryland
Yeah, it is an old one. I posted to make folks aware. Apparently something has changed at HP. I have the credits and the key, but most of the in depth parameters are read only, and I got a message saying I need to take a class to unlock them?just sayin
Today, 03:42 AM #217
- Jun 2007
- Baltimore, MD.
That's odd. I literally did a mild tune on my neighbor's truck less than a week ago. Downloaded stock tune, bought 2 credits, got my new app key, modified tune, and reflashed. No issues and nothing looking different than before. I'll have to look around on their forum when I get some free time.
Today, 07:59 AM #218
- Sep 2024
- Maryland
Were you able to open the full Idle, Airflow and VE tabs?
Today, 08:02 AM #219
- Sep 2024
- Maryland
I ask bc I did a full H/C/I/HDR swap, and cannot go deep into massaging the ratios. Keep getting the message to take the tuning course.
Today, 08:56 AM #220
- Jun 2007
- Baltimore, MD.
Yessir. I will try to get a couple screenshots when I get home.
If you want, I can PM you my email address, and you can send me a copy of your tune. Then we can confirm I am seeing same info as you are.
I actually have unlimited credits for 2002 Chevy/GMC trucks. When I got my HPTUNERS 15 or so years ago, it was a serial cable, Version 1.xx, and it came with FOUR unlimited model years, which was pretty awesome!Last edited by rel3rd; Today at 09:00 AM. Reason: Add info
There are currently 2 users browsing this thread. (1 members and 1 guests)
Obama, Romney Tweak Each Other In Swing States
By Ed Blown Vert in forum Political / Debate ForumReplies: 0Last Post: 10-24-2012, 04:50 PM -
HPTuners Pro
By 99bta6 in forum Parts Wanted / TradeReplies: 0Last Post: 03-18-2010, 03:16 PM -
OEM Radio Tweak
By Sarge in forum GTOReplies: 27Last Post: 01-23-2009, 05:36 AM -
Wanted: 99' Hptuners
By Mark8fish in forum Parts Wanted / TradeReplies: 0Last Post: 06-17-2008, 10:19 AM -
i got hptuners
By mrr23 in forum Computer & TuningReplies: 7Last Post: 12-01-2006, 01:35 PM
