05-31-2008, 06:53 AM #1
Bolt-on Subframe Connectors Install
Are there anything that i need to know or do while install them?
I puchased the UMI Bolt On Subframe Connectors.
I was worried about body flex and such. Is there a certain spot i should put the jackstands?
Any help would be greatly appreciated.
thanks
matt
05-31-2008, 11:13 AM #2
You can put the car up in the air when you install them, but don't tighten them all the way until the weight of the vehicle is on all 4 tires- you want the frame loaded as it normally is when you tighten them up-
I love mine.....
06-03-2008, 08:17 AM #3
A buddy of mine just put the front tires on ramps and jackstands under the rearend. It worked just fine. But that could be wrong, made a world of difference on his t/a
06-03-2008, 07:49 PM #4
I just meant that the suspension and frame should be loaded, not hanging in space- as long as the weight is carried by the wheels and axle, all is good-
06-03-2008, 11:15 PM #5
bolt in subframe connectors or sway bars?
By mammoth713 in forum Suspension and HandlingReplies: 42Last Post: 12-13-2010, 07:27 AM -
FS: SLP bolt on subframe connectors....local picku
By white.lightning in forum Eastern MembersReplies: 19Last Post: 06-22-2008, 01:40 PM -
Subframe connectors, weld vs bolt
By kool-aide in forum Suspension and HandlingReplies: 72Last Post: 11-10-2007, 03:51 AM -
J&M subframe connectors install
By Z28LS1 in forum Suspension and HandlingReplies: 0Last Post: 03-12-2007, 02:10 PM -
F/S: SLP bolt-on Subframe connectors in Omaha, NE
By Rocky Rotella in forum Mid-West MembersReplies: 3Last Post: 02-08-2006, 07:12 AM
