Results 21 to 40 of 40
Thread: what 15" racing wheel will fit?
09-21-2008, 06:32 AM #21
09-21-2008, 07:04 AM #22
so you don't have to grind the fronts if you get spacers? I want to run 15X3.5 fronts. How thick of a spacer do I need? Where can you buy the spacers?
11-14-2008, 11:11 PM #23
greg weld 15x 10 with a 6.5 offset any one think they will fit?? i need a set of back wheels but i could probly wait till spring
11-26-2008, 07:53 PM #24Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
11-26-2008, 07:55 PM #25
12-19-2008, 10:42 AM #26
- May 2008
- delete me too
before you say that i have a set of 15x10s in the back of my 93, it did require a sawzall to the rear bump stops, but they fit other than that... along w/the spacers i have for them. I haven't changed the brake pads on it yet, but i'm fairly sure that i did have new pads on shortly before putting these wheels on
12-19-2008, 10:44 AM #27
- May 2008
- delete me too
04-20-2009, 05:34 AM #28
what is the tire size for the front, along with the offset? is it 1 3/4 on a 4" rim with 195 50 15's?
04-20-2009, 10:27 AM #29
05-11-2009, 04:07 AM #30
05-11-2009, 05:51 AM #31
depends on the tire. last time out i had a 325/50-15 BFG drag radial. almost lifted the front off the ground.
05-11-2009, 06:40 AM #32
Killer!
That sounds encouraging but tough on the rear gear
11-13-2009, 04:03 AM #33
Will 10" wheels fit in the rear given the right backspacing?
What is the narrowest tire that can be put on a 10" wheel?
Anybody know max backspacing that will fit in the rear?
03-08-2010, 03:50 PM #34
03-11-2010, 07:18 PM #35
03-12-2010, 11:37 AM #36
measured with a digital gauge in metric and put the tape measure next to it and the measurement i got was 4 5/8.
03-16-2010, 11:00 AM #37
03-25-2011, 06:47 PM #38
My dad & I are building a drag car out of a 96 z28 and we were wondering what size drag rim and drag slick we can run? We are really new to this and dont really understand the ofset & back spacing issues!!! We would like to run a 10 inch slick!! Any & all help would be very much appreciated!!
06-07-2012, 03:53 PM #39
Bogarts will fit with no grinding or spacer but they cost some coin. Check out SJM Manufacturing.
02-27-2016, 08:35 AM #40
so what is the latest options for 15s in the rear of a 2001 Camaro with stock brakes? have more rims come on the market that don't require grinding or is grinding the calipers the only choice without swapping brakes?
Wanted: 98-02 OEM 16" wheel "ABS" black background center caps
By JayTA98 in forum Parts Wanted / TradeReplies: 5Last Post: 11-05-2012, 12:40 PM -
Ruff racing r280 18"chrome wheel info 18"
By rstewart in forum Wheels and TiresReplies: 7Last Post: 01-20-2009, 12:57 PM -
FS. "newish" Spec stage 5 racing clutch.
By sscrazy in forum Parts For Sale / TradeReplies: 5Last Post: 12-19-2007, 04:10 PM -
FS: Thunder Racing TR227/224 "reverse split" camshaft
By TwistedSS in forum Parts For Sale / TradeReplies: 2Last Post: 06-07-2007, 05:43 PM -
"Chevy Racing" jackets.. Officially Licensed GM products!!!
By Style in forum General ClassifiedsReplies: 27Last Post: 01-17-2006, 10:22 AM
