Results 81 to 100 of 370
Thread: PCV/Catch Can/Crank Pressure
03-18-2009, 11:47 AM #81
03-18-2009, 11:48 AM #82
- Jan 2006
- Shepherd, Michigan
nice Wikipedia copy and past too
03-18-2009, 12:26 PM #83
Wikipedia is great isn't it haha!
Sorry I used to be a Automotive Engineer with Delphi but due to our recession am now in the Nuclear Power Industry. I understand mechanics like the back of my hand but do a job explaining it in laymen sense so I use Wiki. Works for me haha!
03-18-2009, 12:28 PM #84
03-18-2009, 01:00 PM #85
- Aug 2008
- Miami, FL
Pulse Red- 2004 GTO M6
You guys are vacuuming out my head!
on another note, if I do not burn oil, what benefit will there be of me adding a catch can. I use almost no oil over a 4,000 mi OCI on the LS1 so I am thinking that it would not be of much benefit to me. Is my thinking right?
03-19-2009, 04:14 AM #86
03-22-2009, 08:37 AM #87
If you have the entire PCV system deleted and have the double breather set-up, why run a catch can at all?
2002 SLP Camaro SS
Onyx Black
http://www.gmhightechperformance.com/features/0901gmhtp_2002_chevy_camaro_ss/index.html
03-22-2009, 10:30 AM #88
03-22-2009, 10:46 AM #89
- Retired Outlaw Sum Bitch
Problem is the GM engineers haven't built a good/proper PCV system.
03-22-2009, 11:10 AM #90
You're right. Back before pcv systems were even invented thats all we ever did on the old Gen 1 small blocks, it's the way they came, a simple breather on the intake that doubled as your oil fill, and a dump tube at the rear of the block. There weren't even provision in the valve covers at that time. Simple and it worked.
Guess the problem came when the tree huggers decided that wasn't environmentally friendly.
With that being said I guess on these newer cars that have to be tested in certain areas it becomes a question of whether you want to pass inspection or not. The simple breather solution probably won't fly.
03-22-2009, 05:58 PM #91
03-22-2009, 08:55 PM #92
Did mine even though it didn't burn any oil, knock on wood! Bought a billet model, but you can do one for 20 to 30 bucks and it will do the job, I can tell you after a hard day you will drain oil out of the can. Mine has a breather on each valve cover and have had no problems, good stuff.
03-23-2009, 04:53 AM #93
03-23-2009, 08:23 AM #94
03-23-2009, 12:12 PM #95
03-23-2009, 12:16 PM #96
03-23-2009, 02:38 PM #97
Sure
03-23-2009, 06:35 PM #98
03-24-2009, 04:51 PM #99
- Oct 2007
- Beaver Dam KY
I have the truck pcv valve and redid 100 percent of my system.... popped the TB off while I had the pump out. Im really thinking of buying a nice nice catch can. No oil puddled up but dam its greasy feeling. Ill spring for the new catch can when i go ls6.
03-25-2009, 06:39 PM #100
In the process of doing this now!
PCV Catch Can
By Orcus79 in forum Internal EngineReplies: 4Last Post: 08-24-2013, 01:17 PM -
C6 Corvette Catch Can - Catch Me If You Can
By Ed Blown Vert in forum CorvetteReplies: 0Last Post: 07-29-2009, 02:00 AM -
What fuel pressure should I set my fuel pressure safety switch at?
By JAvery20 in forum NitrousReplies: 3Last Post: 04-01-2006, 03:59 PM -
Looking for gauges! nitrous pressure, fuel pressure!
By texasss in forum Parts Wanted / TradeReplies: 2Last Post: 10-29-2005, 09:05 AM
